Usenet speeds down to 6KB/s
I have a premier account but my usenet speed has suddenly gon down from around 200KB/s to 6KB/s any ideas why this would happen? I've used less than 4 gigabytes total so far this month :S
Peak time traffic management by PlusNet (peak time is 4pm -> 12pm) or contention at your exchange. Could be either or both.
Plusnet Staff
Plusnet Staff
Just tried a quick header update on my home connection, came down around 120KB/s. Are you seeing slow speeds on anything else? Try the speedtest on the portal (under connection settings on the left). I'd also suggest rebooting all your equipment (PC, router/modem) and see if that makes any difference.
Rebooting the router seems to have done the trick, should have thought of that Shockedops: .
Thanks for the help
