Usenet - recommended newsreader
Fixes: 57
As a total noob in this area and wondering what all the fuss is about can anyone recommend a simple easy to use and free newsreader to start off with on the PlusNet usenet
channel
There's a really useful guide to this sort of thing here:
http://www.help4newbies.fsnet.co.uk/
HTH
Probably the most used program for usenet is http://www.forteinc.com/main/homepage.php
But you could just use Microsoft Outlook.
Regards,
Tony
If you want to download binaries then you'll need to switch providers and Newsgroup servers. I'm on Eclipse Internet which allows me between 200-235k at PEAK times. Also using Easynews.
Fixes: 57
HTH
I can't get this to open. Tried Internet Explorer and Firefox but it doesn't bring up the java symbol in the taskbar. Any way past the front page please.
Fixes: 57
Still doesn't work but tried google and this link works fine in Firefox
http://www.help4newbies.fsnet.co.uk/home.htm
Thanks for the help
Ben_Brown
We are working to improve the performance of binary usenet for people using our servers, this work should be completed in the near future.
Also this forum is not an appropriate place to discuss the services of other providers, this is better discussed in independant forums such as ADSLGuide.
Will it be before 2007?
ROFL Probaly NOT!
Cool
