Usenet broken?
Usenet broken?
Is Usenet down yet again?
Service status says OK!
Cheers
Fixes: 8
Usenet broken?
Working OK here.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Plusnet Staff
Plusnet Staff
Usenet broken?
It's working fine for me too, what problems are you seeing?
Usenet broken?
At "getting articles" it is doing nowt, ending with a socker error?
Xananews 1.18.1.2
Ziggur
Usenet broken?
It's working for me with Xana. No problems.
Usenet broken?
Yes, had 10 mins to check and it looks like the client is bOrked at the moment, thanks for the replies.
Plusnet Staff
Plusnet Staff
Usenet broken?
Which server are you using and which group?
Usenet broken?
news.plus.net
As you suggested before Dave I have set-up Outlook to test and it is fine, for some reason Xananews has died ;-(
Usenet broken?
Tried a re-install and it wont get new groups, strange ;-)
Will investigate later, have to return to work.
Cheers
RobJM
Usenet broken?
I can't get newsgroups either , when I click on a group after about 30 secs I get this error>
502 Cannot connect to NNTP server 84.92.1.10 (84.92.1.10:119), connect error 10060
Configuration:
Account: usenet.plus.net
Server: news.plus.net
Protocol: NNTP
Port: 119
Secure(SSL): 0
Error Number: 502
Code: 800ccca0
Installed AV program Avast a few days ago but i'm sure I've looked at groups since. Using Outlook Express .
Thanks for any help
RobertJM
PhilBower
Usenet broken?
I have always used the old usenet.server.net server.
Yesterday everything was "normal" but today I could not download anything from Usenet faster than about 10 bytes per second (all other internet connections were fine)
After a lot of hair tearing, Customer Support (many thanks Tony Richardson!) suggested using text.usenet.server.net instead.
That fixed the problem immediately.
Usenet broken?
I am now getting 10060 in Xananews on all PN servers, talkto servers are running fine, and PN is ok via OE and Gravity!
I have no idea Smiley
Usenet broken?
ive had problems for the past 3 hours
im with forteinc, its not them as it works fine through bt.
PhilBower
Usenet broken?
I didn't mention in my earlier post that I'm also with Forteinc and that didnt work either until I changed to text.news,plus.net.
I presume the fault in the news.plus.net server was blocking my Port 119 (or whichever one it is that Usenet comes through).
Phil
Usenet broken?
Strange thing, I am trying to download the latest Knoppix from their torrent site, plenty of seeds and it is not moving, same as Usenet! Probably not connected, but thought I better mention it just in case anyone is having same problems.
