Usenet again!
Usenet again!
Put tickets up for Usenet not running correctly to be told, re-set your connection or you are the only one with a fault!
My Usenet was fine until a few days ago when posting times (my posts) where taking from 30 minutes to 4 hours to appear, I have not changed anything this side, tonight I looked at the Usenet portal and most posts where getting there but not to my reader (Gravity), I also tried Thunderbird and it was the same!
Also note posts in the morning are fine!
It's got me beat ;-)
Usenet again!
yep... ive just got connection errors.
guess its busy.
try it later on i guess Sad
Usenet again!
It's been on the slippery slope for a few days, it is a pity that the response from the tickets only looks like excuses for lack of info (their side), and if they don't know who does Smiley
Usenet again!
well mines working but not maxing out my connection.
its probably plusnets issue.
been fine all eve up to when I posted.
im sure itll fix itself some point.
read im using is reader2 btw.
Usenet again!
Self healing system then ;-)
