Useage counter
Useage counter
I note that the Useage Counter has broken down again. Sad
RE: Useage counter
Good Morning,
Do you mean view my usage?
Kind Regards
Duncan
| Duncan Scotland          Unmetered & ADSL solutions
| Customer Support    for Home & Business
| PlusNet Technologies Ltd. @ http://www.plus.net
+ ------- My Referrals - It pays to recommend PlusNet ---------
RE: Useage counter
> Kind Regards
> Duncan
YES!
RE: Useage counter
Byron: Try this prog. I've been using it for quite some time and it's never let me down. It keeps a running total of your internet time, it has a countdown timer to warn you when you have used a specific amount of time as set by you and alarm functions etc. All you need to do is remember to reset the counter on a each monday so that you don't run over your time allocation. Very easy to use and best of all it's totally free.
It's called "Web Time" and you can get it at...
http://download.cnet.com/downloads/0-10062-100-882532.html?tag=st.dl.10001-103-1.lst-7-8.882532
If the link don't work, just go to download.com and enter Web Time in the search box.
Hope this helps, mate.
RE: Useage counter
> YES!
I have done extensive tests and it doesn't appear to have a problem.
What problem do you see with it?
Kind Regards
Duncan
RE: Useage counter
> > YES!
It hasn't recorded any figures since Thursday.
RE: Useage counter
Thanks for the info., in fact I do have my own logger but it logs total time on line which may not be all Plusnet, when Plusnet is particularly slow I switch to Boltblue or even Freeserve, I have others too. Consequently it shows all time, I like to see Plusnet Time. I do appreciate the advice though and will keep it in mind. Smiley
RE: Useage counter
Hi Byron,
I've sent your problem through to networks for investigation, I've verified it this end.
Regards,
Mike
| Mike Grice.....................Unmetered & ADSL solutions
| Customer Support......................for Home & Business
| PlusNet Technologies Ltd..........@ http://www.plus.net
+ ----- My Referrals - It pays to recommend PlusNet -----
RE: Useage counter
Byron: That isn't a prob with this prog. It tells you the total web time on the particular dial up number you happen to be using at the time. I use two accounts, too and it keeps track of both.
RE: Useage counter
Thanks I will take a look, it seems though there is only one day missing last week on the Plusnet chart. Smiley
RE: Useage counter
Hi Byron,
Sounds like that program that the nemesis recommended is going to be the most accurate form of time management for your internet connections, however I do believe to the best of my knowledge that there are currently no ‘view my usage’ issue’s at this time.
Regards
| Lee Mckenzie.................Unmetered & ADSL solutions
| Customer Support Agent..............for Home & Business
+ ----- My Referrals - It pays to recommend PlusNet ----- +
RE: Useage counter
I, too, am missing my usage for Friday 29th March...
Tim
RE: Useage counter
Dear Tim,
We will look into this.
Kind regards
Kevin
| Kevin Revill ............... Unmetered & ADSL solutions
| Customer Support .................. for Home & Business
| PlusNet Technologies Ltd. ....... @ http://www.plus.net
