Usage limit
Usage limit
Hi
I read the limit bit on the website, but just want to make sure i understand it right.
i can use upto 10gb p/m on peak but i can use as much as i want to off peak?
superloon
Usage limit
what package are u on? Cheesy
Usage limit
Premier Option 1
Whoosh
Usage limit
15gb peak time according to the Plusnet info.
Option 1
Peak-time usage allowance 15GB
Speeds Up to 8Mb
Price £21.99
http://www.plus.net/residential/broadband/broadband_premier.shtml?link=resbb_premierlink
Then look at product usage
Usage limit
Yep off-peak generally has no limit, but there is an unofficial figure. Plus have said that anyone using more than 100Gb would not be welcome and they would look towards moving them to a different ISP.
Mind you, 100Gb would take a fair amount of battering and very few ISP's now would let you get away with it these days.
Usage limit
cheers, yeh i saw the 15gb bit but on another bit it said 10gb then stuff would get lowerd.
dont think i will ever use 100gb, normaly use about 45g/b a month max
Usage limit
Yep restrictions "slowdowns" strat to happen after you reach 10GB
Usage limit
I dont believe they did say that at all!!
I am happy to be proven wrong however!
I think it was more along the lines of, if you regularly d/l more than 100GB on option1 then you should consider upgrading to the next option.
Usage limit
Hmm, can't remember exactly - you could be right. I am going on a post which was made here some time ago, which (at the time) I am sure the emphasis was on moving elsewhere rather than upgrading account type.
James
Usage limit
There are no off peak limits.
Usage limit
Absolutey none at all?
I can download as much as I like offpeak without any traffic shaping applied off-peak?
SW.
3Mb FTTC
RfC2k7
Usage limit
Really, so I can go over 100gb off peak?, dont get me wrong I have no intention of downloading 300 and 400gb but I could go to 150-200 off peak?
kjaerligkatt
Usage limit
This is what has been being said for some months.
From what I recall the 100GB guideline of old was always that, and just whilst PN were migrating to their new traffic shaping model. When full automation came in a few months ago, this 100GB off peak guideline was questioned on the forum a few times, but the answer has always been consistent - there are no off peak limits.
Of course, there is always the caveat about sustainable usage, and PN's right to change the terms, or take action against damaging activity, but the bottom line is that off peak is 100% unmanaged.
Neil
Alecto
Usage limit
Looking at what they say, sustainable usage now only applies to peak time.
I'm amazed, but there you are.
kjaerligkatt
Usage limit
If it became necessary on an individual account, they would only have to refer to the T&Cs, in particular the acceptable use:
overloading a Service
Neil
