Upload Speeds !!
Upload Speeds !!
Just had my line activated to 2mb, the DL speeds are a bit erratic but are reasonable, however i don't seem to be getting an UL speed. Any speed check i do doesn't detect my UL speed, and when uploading i get speed of 1kb !!
It worked fine on my 512kb, i just wonder if its something PN have done ?
I've raised a ticket, but just wondering if anyone else had this problem ?
Ben_Brown
Upload Speeds !!
Have you disconnected and reconnected since your speed was upgraded?
Also have you tried the BT Speedtester? Instructions available at http://usertools.plus.net/tutorials/id/27
Upload Speeds !!
Yes i have !
Upload Speeds !!
The BT Speedtester doesn't detect upload speed, so is of little use.
What speed tests have you actualy tried?
Try the ADSL Guide speed test, and paste the URL shown in the address bar, one you have the results on screen.
Upload Speeds !!
It seems ok now, before none of the speedtests could detect my UL speed but know it does and its fine Cheesy
I'll keep an eye on it !
