Upgrading to premier 1 from PAYG
paulgul
I have just upgraded from PAYG to Premier 1 and have been told there is an upgrade charge of £14.99. I thought this charge was only if the new account was cheaper than the old account. Can someone confirm this upgrade payment is correct
Paul
Plusnet Staff
Plusnet Staff
Fixes: 159
Upgrading from PAYG to Premier should not incur a charge, do you have added usage that makes your product more expensive then Premier Option 1?
 Chris Parr
 Plusnet Staff
James
There shouldn't be a charge. Yes, your PAYG account is marginally more expensive than Broadband Premier, but it's so minimal we shouldn't be charging for it.
Let me know if you choose to upgrade your service and I'll action the request myself.
paulgul
Thanks James, yes the upgrade has already gone through.
Paul
