Upgrading accounts
Upgrading accounts
I'm thinking of upgrading my account from the old £21.99 512kb package to either the 1 or 2mb package but i'm not sure how much this is going to cost.
When you click on the upgrade link you go back to the front page with all the options on, like you were a new user.
Upgrading accounts
There is a FAQ about upgrading here. However, you should also read this as the charges are likely to change soon.
lowry
Upgrading accounts
As pacaya says, take a look at the FAQ (specifically the table) and see what it would cost from there. BT have recently reduced the fee it charges to ISPs for regrades though and so I would hold off so that you can take advantage of that. You may save quite a bit by holding off and waiting for the new charge to come in.
matt Wink
