Upgrade to BB...LLU or IP Stream choice?
Lolaan
I am waiting that all the problems encountered with moving to tiscali is resolved before upgrading to Broadband, at the moment I am not sure if it's a good time to upgrade yet.
If I upgrade from Dialup, will I have the choice between IP Stream and LLU or will I be moved straight away to LLU without having a choice?
If your a PN member already, try this:
http://portal.plus.net/wizard/?wizard_id=20
If you can't access them from dialup, then specify in your join/upgrade request that you don't want LLU.
Lolaan
Thank you squidgey, I'll keep that in mind when I register to broadband.Maybe I'll wait a bit more, see if things calm down a bit. But it's nice to know that you've got the choice.
