Upgrade - how long?
Upgrade - how long?
If I request an upgrade from Plus to Premier, 2mb no speed changes, how long does it take to take effect? If its as suspected next billing date, is there any way of getting it done quicker? (Not really critical but would have to wait 3 weeks or so)
Cheers
Ben_Brown
Upgrade - how long?
Moving from Plus to Premier is an upgrade so it can be actioned immediately. You'd just need to disconnect and reconnect your equipment afterwards to take advantage of the new product.
Upgrade - how long?
Thanks Smiley
