Update on Problem:35406 ?
Eriond
I'm wondering if there is any update for Problem:35406 i am still suffering stupidly high lags to quite a few counterstrike source and battlefield 2 servers
tracerts to 195.20.109.130 range from
1. <1 ms <1ms <1ms router
2. 14 ms 15 ms 12 ms lo0-plusnet.pte.ag1.plus.net
3. 28 ms 22 ms 18 ms gw0-0-0-403.pte-gw1.plus.net
4. 16 ms 17 ms 17 ms v123.thn-gw1.plus.net
5. 17 ms 18 ms 14 ms lonap1.enta.net
6. 19 ms 20 ms 16 ms 62-249-255-186.no-dns-yet.enta.net
7. 13 ms 15 ms 13 ms sov-r1-rtr1.4u.net.uk
8. 17 ms 15 ms 17 ms server109-130.4u-servers.co.uk
to
2. 65 ms 65 ms 57 ms lo0-plusnet.pte.ag1.plus.net
3. 25 ms 22 ms 18 ms gw0-0-0-403.pte-gw1.plus.net
4. 154 ms 210 ms ms v123.thn-gw1.plus.net
5. 17 ms 18 ms 213 ms lonap1.enta.net
one tracert had between 140 and 350 ms on every hop.
Interleaving still appears to be set on even though the request was completed 7 working days ago, the problem used to be confined to peak times but in the last week it has been seen at any time of the day
Mand
The problem is still being worked on by our networks team, Carl is individually building games into Ellacoya to rectify this issue. AIUI both the games you mention should be built in but if you raise a ticket with the port numbers and we can check for you.
The order to remove interleaving shows as completed in BT's system, what does your hardware say? We would need to raise a fault if this shows interleaving still on.
Eriond
thanks for the reply mand, i included the main server ip's along with the port numbers in ticket ID: 20273523
195.20.109.130:27045
195.20.109.130:27025
195.20.109.130:27015
my hardware does not report much on line stats and i cant find interleaving in there, i am going on what my portal connection settings reports.
What router modem do you use? another forum member my know if the details can be retrieved.
Another option is the manufacturers Support Site/Forum/FAQ to see if the question has been asked before.
Eriond
its an edimax AR6004 had it since joining pn so its rather old..but still does the job of connecting
I can't see anything on the web about the line stats. But I did find the contact number for the UK, might be worth asking:-
Phone:- 01908 255981
Email:- support-uk@edimax.com.tw
Found here:-
http://www.inter-comp.pl/pub/manual/AR-6004.pdf#search=%22edimax%20AR6004%20user%20guide%22
