Up To Max,But What Should My Speed Be ?.
Had max adsl now for 11 days & this is what i have on a speed test
Downstream 2,488.8 Kbps ( = 2.4 Mbps )
Upstream 376.1 Kbps ( = 0.4 Mbps )
Line says it is connected at 7.6 mbps,so should i not have better download speeds.
Anyone that can give me some info on it all would have my thanks.
Flybynight.
1 REPLY
What number is shown at the link below? This is the value BT have told PN to limit your connection speed to ... it can take 3-4 days to change.
https://portal.plus.net/my.html?action=stable_rate
SW.
3Mb FTTC
