URGENT. Cgi problem
URGENT. Cgi problem
None of my sites hosted on the cgi server are working. All scripts are showing "not found". Please either fix the problem or return my site to the old server asap. Hopefully you haven't "lost" any of my files either!!
Mark
URGENT. Cgi problem
http://cgi.didit.force9.co.uk/ working fine here...
URGENT. Cgi problem
Don't panic Mr Mainwaring Cheesy Note to self: DO NOT look at web pages and scripts when F9 are migrating your account, it only makes you look stupid Shockedops:
Mark
P.S. I have been following the upgrade with Perlinfo at http://cgi.force9.net/cgi-bin/perlinfo.cgi, this is also not currently responding. Will it stay in the same position or move? What I really want to know is: Has the version of Perl been updated? I have a classifieds script I would like to run but it uses version 5.8.0. Hopefully a new version will have been installed with the upgrade?
URGENT. Cgi problem
Its gone... I actually meant to mention it to one of the staff to ask Ben to redirect it to the new script as thats whats linked everywhere http://cgi.force9.net/cgi-bin/perldiver/index.cgi is the new one Smiley
Unforunately, perl is version 5.6.1 Sad
URGENT. Cgi problem
The old URL now works as well Wink
URGENT. Cgi problem
Don't suppose anyone in CS knows if there is likely to be an upgrade to Perl 5.8.0 in the near future do they? I might be being pedantic, but it seems silly to spend all that money upgrading the server only to have an old version of the software installed!
Cheers
Mark
jberry
URGENT. Cgi problem
I will ask internally why we are nut using the latest stable version.
Regards,
lhorwath
URGENT. Cgi problem
Perl has been upgraded to 5.8. This was completed late yesterday.
regards
Luke
URGENT. Cgi problem
Brilliant. Thank you very much Cheesy A much better result than I got when I raised a ticket. Now all I need to do is try to get my new script to work Wink
Regards
Mark
