Turning On Spam Protection Question [Split]
alben
How do I check my secondary email addresses? why does the login to webmail need the same login as to the member centre, I have already logged in for link:censored.
[Moderator's note by Jonathan (chillypenguin): Inappropriate language removed from post]
alben
Ok penguin how about a answer?
:shock:
alben
As an extra I would ask how you would feel if you and your family had been recieving the filth we have been exposed to. I am angry!
I'd say that the reason you need to login to webmail again (even if you're already logged in to the Portal) is because many users use multiple mailboxes, and automatically logging on to the default mailbox isn't helpful in those circumstances.
To answer your other question, logon to secondary mailboxes using username+mailbox as the username, and the password for that mailbox.
Which is what I said when you asked the same Q here
alben
Give me a from the start, flowchart how to login to webmail from a secondary address, thanks.
See the other thread!
alben
What I wish to do is to able to access all our email accounts online the ones I had to take out of outlook express because of the offensive spam that plusnet has allowed us to recieve. Webmail will only allow me to login with my forum login. I can use web2mail to do this but not frpm plusnet. Puzzled ?
Can we keep this problem in just one thread (the other one) as cross posting causes confusion.
Thread locked.
Please you this thread as suggested by Peter;
http://portal.plus.net/central/forums/viewtopic.php?t=56319
Jonathan
aka Chilly
I have split that part away from the original thread, as it was unfair on the OP that the thread had been locked after it had been taken off topic.
Jonathan
aka Chilly
