Truncated e-mails
cardsharp
Truncated e-mails
I have discovered that e-mails to my domain are being truncated by PlusNet. I have filed a call (id: 2220648Cool but it does appear to be fairly serious.
Any e-mail (well, all that I have tried) is truncated when there is a single period (".") at the start of a line. The message is truncated from this point.
It is not an HTML issue, and the problem can be seen in WebMail so it is not e-mail client-related. It does not occur with ".." at the start of the line!
Anyone else seen this?
Fixes: 70
Truncated e-mails
Yes.
I saw a problem a while back where there was an intermittent issue causing Dspam to leave a single full stop on a line. This caused Exim to believe that the email had ended, thus truncating the rest of it, including any attachments.
Not sure if this is the same thing. I'll try and find out.
Rgds,
Plusnet Products Team
Fixes: 70
Truncated e-mails
Problem now being investigated.
I've passed your ticket back to you.
Kind Rgds,
p_w_d_stone
Truncated e-mails
Don't know if this is the problem, but we also use SquirrelMail at the University where I work, and anything after a "--" is greyed out and almost impossible to see. The text is still there and viewed if highlighted, but is almost invisible to the naked eye.
With most users using "--" prior to signature and busily forwarding and/or replying to messages threads rapidly became pointless. The only work around we found was to-
a) not use a signature for forwards and/or replies
b) set the client to add the signature at the end of the combined message, not your contribution to it.
c) change "--" to "-" or "---".
Messages display correctly in clients regardless.
If your problem only occurs on webmail this may be a similar (intentional) quirk of SquirrelMail.
cardsharp
Truncated e-mails
PN has determined its Anti-Spam solution is the cause and is currently testing a fix.
p_w_d_stone
Truncated e-mails
I didn't spot that Shockedops:
Fixes: 70
Truncated e-mails
Hi Peter,
This is unrelated to the problem being discussed in this thread. The behaviour you're describing is intentional AFAIK.
The signature separator (dash, dash, space) is a recognised convention. Many email clients (Thunderbird being one) will strip anything after this separator when replying. That's one of its purposes.
Do you need to use a signature in these circumstances?
This is the recommended convention.
Which kind of evades the point of the separator but would work.
I'd agree that this down to SquirrelMail not handling the separator as gracefully as a standalone client.
Kind Rgds,
Truncated e-mails
Just like to add that I have also been having problems with receiving truncated emails like this - I've added my username to the problem's page and will await a fix eagerly! :?
Deb.
p_w_d_stone
Truncated e-mails
This is intentional- I don't look after mail servers, simply work on the helpdesk, but I was the one getting the call about "missing forwards" so I did some research.
In the Faculty area where this problem was reported most computers had been set up by a member of staff using a template with two rather than three dashes. Unfortunately the issue of where signatures should be added was not considered either.
The University requires that a disclaimer is added to all outgoing messages, since these may includes forwards and (more often) replies it has been a long standing policy that clients are set up to include a signature in all circumstances. Perhaps a more elegant solution might be to append all messages leaving the network with a disclaimer, preventing incorrectly set up users/workstations ignoring the policy through ignorance. The disclaimer could also then be used with a Faculty specific (Faculties are assigned blocks of IP's) marketing message to inform recipients about new courses etc. Unfortunately, since this requires both money, infrastructure and development time this suggestion was dropped.
This is what we did when physically present at a workstation.
This was a relatively straight-forward work-around to take someone through over the phone, I always asked users reporting this to change their signature to three dashes as you have stated above. With users working across the East of England it was not always possible to have immediate access to their machines.
