Trafic Management
Trafic Management
Just paid my monthly subscription to BB+ so I thought the traffic mangement would have been lifted, no such luck its as slow as ever, iv'e just done a speed test:
Your current speed is:
126.00kbps
Which means you can download at 15.75 KB/sec. from our servers. Our results show that your current speed is below the level we would expect for your product, you may be able to increase the speed of your connection by adjusting your settings.
53.3 kbps 56k Dial Up
64 kbps ISDN 1 Channel
126 kbps YOU
128 kbps ISDN Dual Channel
460 kbps ADSL 500
920 kbps ADSL 1000
1840 kbps ADSL 2000
Hm......so not much better than dial up.
Anybody have any idea if it does get lifted or am I stuck at this speed from now on?
Trafic Management
As explained in many other threads where this same question has been asked (that's a big hint to use the search function Wink), it can take up to 2 days from your billing date for the management to be removed because it is done manually.
Traffic Management
Well I would use the search function but my connection is so slow it would take forever. Cry
Trafic Management
Got these emails today
No1
Your peak usage for this billing month has exceeded the product design
therefore Level 4 Broadband Plus usage management has been applied to your
service during peak hours. Your Broadband service will continue to be
managed until your next billing date at which time peak-time usage
management will be removed.
No2
This email is to notify you that you have successfully passed your billing
date therefore peak-time usage management has been removed from your
service.
So if usage management has been removed why is it still so slow>>>>>>
129.80kbps
Which means you can download at 16.23 KB/sec. from our servers. Our results show that your current speed is below the level we would expect for your product, you may be able to increase the speed of your connection by adjusting your settings.
129.8 kbps YOU
460 kbps ADSL 500
920 kbps ADSL 1000
1840 kbps ADSL 2000
