Todays best speed test - 132.10kbps
132.10kbps - just feel like posting it, im going to post it every day, just to make me feel better!!! Theres nothing i can do im in an arm lock pay up 114 pounds or i cant leave
Im on LLU and received a disgusting 89.3 kbps
If you wish to post up bad speed results, then please put them into context, by giving details of your account type and usage.
Also include if you are on BT wholesale or Tiscali.
Chilly
winnipeg1823
snap, 132K 8.10pm and 93K at 5.15pm so it is improving!!!!!!
Broadband Premier (op.1)
Average Usage - 16GB a month INCLUDING BOTH Peak, and Off Peak.
Im on LLU, therefore Tiscalli
19-02-2007 20:14:42 95.6
19-02-2007 19:15:29 89.3
18-02-2007 17:07:09 136.1
17-02-2007 16:26:24 240.2
PAYG LLU Tiscali
My router is sync'd at 5,500kbps. In the day my speed is 4.5mbps.
In the evening and now at 9pm I get 100kbps or less.
This is what I've had for 2.5 weeks and I've shifted from BB+ to avoid these problems.
Plusnet Staff
Plusnet Staff
Please can you ensure that you raise a ticket if you haven't already so we can ensure that this is escalated within Tiscali, the faults guys have seen a number of reports over the weekend and we've fed that back to them so they can continue to work on it but any extra information you can supply could be invaluable in resolving this.
I have raised a fault instead of a ticket ( ID: 21360789 ).
However, when raising a fault, i had chosen problems with SPEED earlier on, and later it asked me about connection dropping, or browsing problems (It was neither of these since i had speed issues) but i chose problem with connection dropping. I do not know what i should have done. However hope this can be resolved.
BB+ customer, this evening 308 kbps at 18:00. Be better off in Africa, even they can get 4mb+ via satelite!! 308kbps over copper and fibre backbone.
Fixes: 8
Never mind a raw speed test result, what's browsing like? Plusnet have been trying to address that specifically and have said that speed test results may be degraded as a consequence.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Richchad
What a nightmare....took ages to load this page now...
:x
Date Downstream Upstream
20/02/07 18:29 89.16 Kbps 161.07 Kbps
Browsing is better than yesterday but i was running at 130-150kbps. Browsing satisfaction has a positive correlation to general speed, especially when under 1mb, after that general browsing isnt vastly improved. But what do i know IS degree and 3 years in IT.
chadwell
come round mine im blistering along!!!! Funny watching images load section by section, takes me back to searching for blueies in the 90's!!!
