Tiscali / LLU question
If + net chose to move me to Tiscali LLU, would it be possible to migrate between LLU providers with a mac? or is it STILL a "cease & reprovide" jobbie?
If I can migrate between LLU providers, I think I wait & see, if I can't think I have to find a backup ISP incase I get moved to Tiscali LLU ...
JonathanW
I believe that it depends on the LLU provider that you'd be looking to move to, though at the moment I think that in the majority of cases it is going to lead to a cease and reprovide. That being said BT are looking at the various migration paths that are needed to make LLU more viable as an alternate to the standard BTW offering.
In my opinion the LLU-LLU provider migration route will not appear until after the LLU-BTW route, which itself is likely months away from functionality and a state of stability. It took a very long time for the current MAC system to be implemented and work smoothly.
thanks for the reply Smiley
Guess I have to start looking for a alternate ISP or go NTL / UKO, if I get moved to Tiscali LLU. Hopefully I won't have too Smiley
