Tis the season to be jolly...
James
So, when reporting any speed or connectivity faults, you should always:
- Change filters
- Use master socket
- Try test socket behind master faceplate if possible
- Try another modem/router if possible
- TURN OFF XMAS LIGHTS!
XMAS LIGHTS ARE BAD
1 REPLY
davebrown
Thanks for the reminder about the Xmas Lights James.
Platform performance was very good last night, I think you can see this by the reduced activity in the forum.
Many thanks for all your efforts James & have a nice Xmas break, I think you deserve it Cheesy
Kind regards
Dave
