Times
Times
Times quoted on Plusnet are confusing.
For instance, what does 08:15 pm mean? There's no such time!
It's either 0815 or 2015 if you're using the 24-hour clock, or 8.15 am or 8.15 pm if you're using standard British notation. (If you want to show 8.15 am, leave out the preceding "0").
Just being pedantic but it's confusing me!
George
Times
How the time is displayed to your on the forums can be set by yourself.
Click on the "Profile" link above, and locate the needed section. A link is provided to the doucmentation, so you can customise the date format.
Times
All makes sense now!
Thanks,
George
