Ticket ID: 19346325 still not answered
Can anyone from PN on here get round to answering this ticket, I'm getting a little peeved now.......
Post your ticket here if you think its anything the community can help with?
Im sure we'd all be glad to help if we can.
Ok be prepared its a long one.....
[Support Wizard Journey] [Technical query] [Other] [Customer couldn't find a wizard option for his query please review the need to change the wizard] [Additional Information] Hi.Ok my stable rate has now changed to 7000...My router is reporting that it is syncing at 8128 down and 448 up but Im only getting about a 3mb connection if lucky.Just tried your speed test and it reported that I could download at 2320kbps...Not very good beings though everything else is reporting higher..... Hope to hear from you soon.Oh by the way Been on max since last tuesday..
Your comment 7:22pm, Tuesday 9th May 2006
I just tried speed test again and got an amazing 1404.8 kbps.....even worse than a 2mb connection...don't you thinkHuh
Your comment 10:17pm, Tuesday 9th May 2006
Just tried speed test again and guess what a speed of 1328.8 kbps....wowwwwwww.If this is what maxdsl is about then why bother....I know its not your fault whoever answers this ticket but this is taking the mick..
Your comment 4:38pm, Wednesday 10th May 2006
Read above posts...Router still sycing at 8128 down 448 up and PN stable page reporting 7000. Tried speed test and yet again poooooooorrrrrr. What is wrong with thisHuhHuh?
Link:CUAremoved 5:26pm, Wednesday 10th May 2006
Dear Mr Antrobus,
In order to investigate this further can you perform three speedtests one of which has to be performed between 12am and 7am
The instructions to run the tests are on the following link
http://usertools.plus.net/tutorials/id/27
Regards,
Link:CUAremoved
To administer your account and for all your help and support requirements visit http://portal.plus.net/index_nlp.html
Your comment 6:43pm, Wednesday 10th May 2006
Ok first test done at 18:33pm result 2007kbps.. Router still reporting sync at 88128up and 448 down and plusnet stable rate page 7000... Will report second test around midnight and one at around 2:30am....
Your comment 9:48pm, Wednesday 10th May 2006
Ok here is my second speed test results:
858 kilo bits per second (Kbps)..Router is still sync at 8128 down and 448 up and plusnet stable rate page still reporting 7000....
Your comment 12:27am, Thursday 11th May 2006
Ok just done speed test again at 12:24am and results are 2025 kilo bits per second (Kbps). Router still sync at 8128 down 448 up and PN Stable page still says 7000... I have had one day where router sync at 7904down...but the rest of the days 9 and a bit to be exact have been at 8128. I will do another speed test in around an hour...
Your comment 1:36am, Thursday 11th May 2006
Ok here is another speed test done at 01:34am....2500 kilo bits per second (Kbps). Router still sync at 8128 down and 448 up and PN stable page still report 7000.....
Your comment 4:14pm, Thursday 11th May 2006
Ok now on day 10ish...Here are the stats I have received from router from 3rd may at 15:30pm.
Noise margin:26 up 8 down
output power:10.5 up 20 down
Atten:18 up 29 down
Sync rate 8128 and 448
4th May
Noise margin:25 up 8.5 down
atten: 18.5 up 29 down
sync still at 8128 down and 448 up
5th May
Noise margin:26 up 5.5 down
Atten:18 up 29 down
6th May
Noise margin:26 up 9.5 down
output power:11 up 20 down
atten:18 up 29 down
7th May
Noise margin:26 up 9 down
power output:11 up 20 down
Atten:18.5 up 29 down
8th May
Noise margin:26 up 6.5 down
atten:18.5 up 29 down
9th May
noise margin:26 up 10 down
10th May
noise margin:25 up 9.5 down
11th May at 15.56pm
power output:10.5 up 20 down
still sync at 8128 down and 448 up.
PN Stable rate page still at 7000 and my speedtests still at around the 2000-2500 mark.
Your comment 4:34pm, Thursday 11th May 2006
Oh just to add. Before I received Maxdsl the BT page said that I could receive between 6.5mb and 8mb... So can you tell me where it is..
Your comment 4:44pm, Thursday 11th May 2006
Just done yet another speedtest and result was 1918.9 kbps.........Please see above posts for all other relevent info..Thanks
Link:CUAremoved 5:35am, Friday 12th May 2006
Dear Mr Antrobus,
This may be a incorrect setting on your account. I'm passing you ticket through to be checked.
[Internal]
Please check/change account speed.
Regards,
Link:CUAremoved
Link:CUAremoved 2:07pm, Friday 12th May 2006
Dear Mr Antrobus,
I have now carried out some maintenance on your account, Please disconnect and reconnect and then your speeds should start to rise.
Kind Regards,
Link:CUAremoved
Your comment 2:20pm, Friday 12th May 2006
Hi and thanks..Juust tried a speed test and its a little better 3640.9 kbps.. Not as good as what BT said I could get between 6.5mb and 8mb..Heres my stats once again from 2pm
Noise margin:18 up 9.5 down
Your comment 2:47pm, Friday 12th May 2006
Ok just done another speed test and result was 2973 kilo bits per second (Kbps). Router is still sync at 8128 down and 448 up and PN stable page still on 7000...
Your comment 7:01pm, Friday 12th May 2006
I think it may be time to remove the data limits.....Still sync at 8128 and 448 and PN stable page still at 7000...Speed test just done came up with 2730Kbps....
Your comment 9:02pm, Friday 12th May 2006
1575.5 kbps
Your comment 10:03pm, Friday 12th May 2006
Oh forgot to add router has not lost sync or reset itself for over 7days.....
Your comment 12:29am, Saturday 13th May 2006
Speed test just done and got 774 kilo bits per second (Kbps), Router sync at 8128 down 448 up and PN Stable page still reading 7000
Your comment 11:36pm, Saturday 13th May 2006
Stable rate page now at 7500 and router still sync at 7128 down and 448 up. No disconnections etc etc...Im just about to hit 12th day and no massive speed up...
Your comment 11:45pm, Saturday 13th May 2006
Sorry I meant to put 8128 down not 7128
Your comment 12:30pm, Sunday 14th May 2006
Just tried yet another speed test and result was 1745 kilo bits per second (Kbps)..Router still sync at 8128 down and 448 up and PN stable page reads 7500....
Your comment 3:26pm, Sunday 14th May 2006
873 kilo bits per second (Kbps), Stats are all the same....This is'nt very good don't you think....
[Moderator's note by Mark (pcsni): CSA names removed as per the rules. Please dont post these details. Thanks]
Has interleaving been applyed to your account? (check in router stats page)
also were you on 2mb before the MAXDSL. If so, did you achive a good speed then?
Interleaving is not applied on my account and yes I had 2mb before..And line was stable then....I have a few CRC + HEC errors but these are minimal compared to the received superframes fast and transmited superframes fast..Less than 1% overall of which I have been told is not a problem oh and yes I always acheived top speed on 2mb
JonathanW
Interleaving shouldn't cause issues such as this one, as its generally something that they'd try along with reducing the speed that you're synching at.
I've bounced the ticket through to our faults team and they'll pick it up on your behalf and investigate further.
Thankyou very much Jon...Much appreciation
Well still no change on this situation...............Im self employed and if I ran my business like this I'd soon be out of a Job...
Mand
Hi
This is with our faults team at the moment, they do have a bit of a backlog due to MaxDSL issues but will update your ticket shortly.
Same here Sad
But by the time PN and BT have finished "making my broadband work as it was sold to me" i.e. ACTUALLY WORKING and I whack an invoice in their direction for dial-up costs, failing to provide a service on a REGULAR basis, then I'll probably be able to retire :-)
Well, that's the ONLY thing that keeps me going........... Wink
Sort this problem now and sort out the speed issues...I have had enough of you making me run round the bush........ABSOLUTE DISGRACE of speeds tonight.. I may as well get 2 baked bean tins and some string..it would be faster...
593 kilo bits per second (Kbps),
CS performed "some maintenance" on my account last night, told me it would "fix the issues" of my poor speeds, and promptly closed the ticket. Guess what? IT DID ABSOLUTELY NOTHING!
I am now browsing other ISPs and will request my MAC code from PlusNet. I've had enough of their lies and gutter-level service... and would suggest every other single unhappy customer do the same.
craign
Maybe silly, but did you reset your router after the CS said they'd fixed the fault?
(FWIW, My PN Maxdsl speed setting increased last night on the 'Connection Settings' but to get the higher speed I just had to reset the router - I guess this reconnects at the PN end and picks up the new profile speed setting.)
BR
Craig
I'm using a Speedtouch 300 USB modem so it's technically reset everytime I boot the computer in the morning. It's got the latest drivers which support 8MB speeds, so PlusNet are basically not providing the service which I'm paying for. As usual.
Add to this the constant disconnections, and the poor email service, and I've had my fill of their constant deluge of lies and below-par service so it's MAC time and another lost customer for them. Maybe one day soon they'll realise that people are leaving them for the same reason...
Still no replys to my tickets.....This is a quality ISP Not!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Plusnot,tenparc
