Ticket 20548064: Plusnet Help Please
sophos9
Plusnet (Dave Tomlinson)
Please can you take a look at this ticket and supply the results of the Woosh test please before I have to call BT out.
I dont buy that I'm limited to a 288 IP Profile. I was connecting a 2mb no problem and even BT say I should have a 3.5mb on dslMAX
I'm syncing around 480kbps and am 2.4km from my exchange, plugged into test port, quiet line test seemed OK, SNR Margin of 16db
Someone help... Sad
sophos9
To add to this confusion...
How come my upload is unaffected? Its the same as when I had an 8mb connection
How come my profile is still set at 8000kbps at plusnet?
Someone please help, plusnet support sux at the mo...
sophos9
Where has everyone in this forum gone? Has EVERYBODY jumped ship?
BOO!
hahah
i set fire to all their cats
*should
but yeah its like a ghost town
i read that big link:censored from the marketing guy for plus.net on adslguide forum pretty nice going...he said all the staff would be here...probably scared?
BOO!
[Moderator's note by Daniel (no7olivier): Removed swear filter evasion.]
sophos9
The change is here is unreal, used to be such a friendly helpful place and now, its like barron wasteland
Plusnet, what have you done...
Same
I have an open case with Plus atm. I am having the same issue as you. I have a 8Mb/s profile and was getting fine speeds, but recently this has dropped massively.
I was asked to test a few things (basically jump through a set of hoops), which I have done and now await there reply. The replies are very slow coming though, and now I have proven it is at their doorstep.
Once I get a reply I will post back in this thread.
Cheers
sophos9
Please do mate, would be good to get a resolve... PN Support have now contacted BT to raise a fault!
really? so they are at work.
wish they would do something to say hello. like replying to my ticket. or to all the nasty stuff i say in here to try and get some attention.
BOO!
No I guess they are not at work, I get really intermittent replies.
Anyway I have posted again in the ticket stating this is not single instance cases, but a wider issue and thier issue to boot.
Here are some examples of the speeds I have got:
Its up and down like a 'whore's drawers'
23-10-2006 22:05:55 3736.1
23-10-2006 22:05:30 0
23-10-2006 22:05:07 0
23-10-2006 20:55:21 4945.9
23-10-2006 20:55:20 0
23-10-2006 20:55:20 43663.1
23-10-2006 20:55:15 244072
23-10-2006 20:55:01 4160.1
23-10-2006 20:16:20 602.5
23-10-2006 20:16:04 605.4
23-10-2006 20:01:52 4945.9
23-10-2006 19:31:35 1294.6
23-10-2006 18:45:57 1961.1
23-10-2006 18:42:09 998.6
20-10-2006 17:19:22 480.4
20-10-2006 17:17:00 491.8
19-10-2006 19:18:02 198.2
19-10-2006 19:10:08 472.2
19-10-2006 19:07:35 480.5
19-10-2006 18:50:27 442.1
18-10-2006 20:37:48 477.1
18-10-2006 20:37:20 476.9
08-08-2006 21:05:11 4205.3
08-08-2006 21:04:48 4216.9
08-08-2006 21:04:35 4128.3
08-08-2006 21:04:11 4344.4
13-07-2006 17:35:58 4418.6
05-07-2006 16:35:06 2289.5
27-06-2006 17:59:20 3962
27-06-2006 17:59:16 3951.8
27-06-2006 17:58:36 3771.6
27-06-2006 08:07:44 6004.4
27-06-2006 08:07:32 6553.6
sophos9
Have you ran a BT speedtest?
What modem stats do you have?
Also, have you connected your modem to the test port?
Have you ran a "quiet line test"
Sorry for all the questions....
Yeah done both.
Results below;
Test 1 @ 17:40 on 20/10/06
Result shown 480Kb/s
Test 2 @ 18:15 on 20/10/06
Result shown 242Kb/s
Test 3 @ 18:45 on 20/10/06
Result shown 483Kb/s
Test 4 @ 18:50 on 23/10/06 (OMG primetime!)
Result shown 5051Kb/s or 4.93Mb/s
Test 5 @ 19:21 on 23/10/06
Result shown 3940Kb/s or 3.85Mb/s
The router shows this:
Line Rate - Upstream (Kbps): 448
Line Rate - Downstream (Kbps): 7648
They are fully aware of this and once they get around to responding to the ticket I will post the mixed bag of replies I am sure to get.
Cheers
sophos9
Can you look for something that says SNR Margin in the stats of your modem
What else do you have in the house?
Have you checked your exchanges VP status?
I am not at home right now.
But I have no reason to doubt the signal to noise ratio. Nothing has changed
These checks were all performed with no other system in the loop.
I have not checked the exchange status either. I suppose I could... :roll:
Also, I set a couple of test in progress before heading to work this morning, maybe the fairys fixed it over night? Mind you that means the Cobbler has some work to do now...
A couple of extra tests this morning before setting off for work;
24-10-2006 07:22:21 5912
24-10-2006 07:22:00 2195.7
24-10-2006 07:21:41 6004.4
Still flexing up and down, but looking more promising.
sophos9
