Terrible speeds
bluejam
Terrible speeds
For about a week now I've been getting absolutely awful speeds on pretty much everything, but namely http (general web surfing etc) speeds. It's no exaggeration to say I could get around faster on 56k. I checked in here a few days ago and noticed a thread where other people were having a similar issue, but it's gone off the radar now...so has that been fixed?
I've ran spyware/virus checks to ensure it's no fault at my end, too.
Plusnet Staff
Plusnet Staff
Fixes: 159
Terrible speeds
hi there,
Can't see any problems on your account, what does a BT Speedtest give you?
 Chris Parr
 Plusnet Staff
James
Terrible speeds
You're actually on a fixed 2Mbps product currently. Would you like me to move you to a Max service? This may or may not help with regards to your speeds. However, we get better diagnostics on Max services aswell so may well be able to offer further help once the order is completed.
holdtight
Terrible speeds
bluejam if you have a router and can paste your line stats here it would help us see whether an upgrade to maxdsl will help you
Can you also copy and paste the results of the BT test that Chris has linked you to
It will help us to see if this is the source of the problems your having
bluejam
Terrible speeds
Hi, I had to install a java applet for the BT speedtest and that took over an hour. The results are as follows-
48 kilo bits per second (Kbps), your service bandwidth will have been quoted to you in kilo bits per second.
Your IP address is 80.229.20.219, your browser is reported as being Mozilla 5.0 and is running on Windows XP.
BT would regard the speed ranges shown below as normal service:
For 250kbps End Users speeds between 50 - 250kbps.
For 500kbps End Users speeds between 100 - 500kbps.
For 1000kbps End Users speeds between 200 - 1000kbps.
For 2000kbps End Users speeds between 400 - 2000kbps.
and my line stats (at least I think this is what you mean) are as follows-
ADSL Status Information
Status:
Status
Configured
Current
Line Status
SHOWTIME
Link Type
Fast Path
Date Rate:
Data Rate
Stream Type
Actual Data Rate
Up Stream
288 (Kbps.)
Down Stream
2272 (Kbps.)
Operation Data / Defect Indication:
Operation Data
Operation Data
Upstream
Downstream
Noise Margin
11 dB
12 dB
Attenuation
42 dB
35 dB
Defect Indication
Indicator Name
Near End Indicator
Far End Indicator
Fast Path FEC Correction
0
0
Interleaved Path FEC Correction
0
0
Fast Path CRC Error
1
40
Interleaved Path CRC Error
0
0
Loss of Signal Defect
0
Fast Path HEC Error
0
0
Interleaved Path HEC Error
0
0
Statistics:
Statistics
Received Cells
816722
Transmitted Cells
3236795
James
Terrible speeds
bluejam
Terrible speeds
Yes okay, move me to Max, please. Assuming it won't cost me anything.
p_w_d_stone
Terrible speeds
The regrade to MaxDSL is free of charge.
James
Terrible speeds
Not a sausage Smiley
I've placed the order for you now and it should complete in the early hours of tomorrow morning. Give me a shout if you have any problems.
bluejam
Terrible speeds
Okay thanks, James :-)
