Terrible latency
StuWard
Terrible latency
Atm its impossible to play any online games and i can't even connect to teamspeak servers. Ther connection is continously timing out.
What have you done to your service PN ?
Terrible latency
@ stuward
There is a thread not a million miles from here discussing the problems with the teamspeak server which can be found here
Your best bet is to have a look in that thread before starting a new one.
Regards,
Roger.
StuWard
Terrible latency
This is not about TS its about general crap connection
TS was just a case in point
Re: Terrible latency
Right, before you want to bawl me out - that is what you said right there I appreciate you said online games, but you specifically mentioned teamspeak, so my apologies for not having got it right this time.
Have you done any speedtests? for example at http://www.speedtest.bbmax.co.uk/ or http://test.speedtester.bt.com:50301/
The latter should give you a IP profile and actual line speed.
Are you also using a router or USB modem? what are your line stats?
Is interleaving switched on by any chance? sometimes this causes latency problems particularly for games - if it is on, then you can request to have it turned off again.
I hope this has helped.
Roger
StuWard
Terrible latency
Line stats
ADSL Link Downstream Upstream
Connection Speed 1632 kbps 416 kbps
Line Attenuation 53 db 15.5 db
Noise Margin 9 db 7 db
Netgear 834G router
The speed test gave me
782 down
205 up
I haven't asked for interleaving to be switched on, but i'm not sure what PN / BT have done on that one
StuWard
Terrible latency
And to add to the problems.
I left my PC on all night downloading a well seeded torrent, and it managed to d/l a whole 45mb averaging 5k.
So much for offpeak downloading
