Terrible Speeds - Help a n00b please
Guys
Excuse this post if its yet another re-hash etc. I am just curious to know if Im been "shaped" or whether I have a BT issue
Early morning before going to work I get 230kbs using FTP (2mb line), yet if I run this same FTP when I get home at night I only get 20kbs-40kbs. Yet at the same time the Plusnet speed checker says I can d/load at 1.59mb
Ive checked the server etc and it is not "clogged" plenty of free bandwith. And all other ftp site i go to exibit the same behaviour
Also, I have a teleworker account, and thought I was not to be shaped ?
Any advise appreciated
goto this address
http://usertools.plus.net/@gateway
and check what gateway you are on
if you are on :
PTE-AG1
PTE-AG2
your connection is probably going to be link:censored up
disconect and reconnect until you end up on
PTN-AG1
PTN-AG2
and you should be good
[Moderator's note by Tom (tomspcs): Please do not try to intentionally avoid the swear filter. BBCode has also been enabled for this post to allow for mod comments to display properly.]
Having looked around I cant seem to navigate to the above link. Does anyone know how to get there, so I can check in the future.
Thanks in advance.
A
Weird, it works for me.
What you can do instead is do a tracert to google.co.uk or something.
Do this by pressing the start button, choose run.
Type cmd press enter
now type :
tracert www.google.co.uk
you should so something like this :
E:\Documents and Settings\Carl>tracert www.google.co.uk
Tracing route to www.l.google.com [66.249.87.99]
over a maximum of 30 hops:
1 <1 ms <1 ms <1 ms SpeedTouch.lan [192.168.12.11]
2 17 ms 18 ms 16 ms lo0-plusnet.ptn-ag2.plus.net [195.166.128.53]
3 22 ms 22 ms 21 ms ge1-0-0-204.ptn-gw1.plus.net [84.92.3.105]
4 16 ms 16 ms 17 ms ge0-0-0-22.pte-gw1.plus.net [212.159.4.9]
5 15 ms 16 ms 16 ms t2a4-ge4-0-1.uk-lon1.eu.bt.net [166.49.211.133]
6 16 ms 15 ms 16 ms t2c2-ge7-3.uk-lon1.eu.bt.net [166.49.135.114]
7 16 ms 15 ms 17 ms t2a1-ge7-1.uk-lon1.eu.bt.net [166.49.135.110]
8 17 ms 17 ms 17 ms 195.66.224.125
9 18 ms 17 ms 18 ms 66.249.87.99
Trace complete.
see my line no.2
" 2 17 ms 18 ms 16 ms lo0-plusnet.ptn-ag2.plus.net [195.166.128.53]"
shows i am on ptn-ag2
Hope that helps, post your complete tracert if you are confused ill help you out
I think PN may be having another 'issue' - just checked the speedtest domain and got 1840kbps, about 1600 on Plusnets and a stunning 48kbps on ADSL Guide...
Looking at some traceroutes it looks like the delay is on my initial connection into PN and gets worse as it goes through PN's network:
I notice though that as usual the fault status page shows no faults Sad.
hmm
ok im connecting to pte-ag2 but eveytime i reconnect i get it - How do I change onto another one ?
(thanks for the help)
The allocation of users to a gateway is done in a round robin fashion so user 1 gets gateway 1, 2 gets 2, 3 gets 3, 4 gets 4, 5 gets 1 etc etc.
So the only way of changing is to disconnect and reconnect until you get a different gateway - very hit and miss.
For PN: Are you having speed/routing issues tonight given I know my exchange/line etc isn't at fault but traffic outside of PN is slower than dialup and internally isn't too hot either.
Yeh if you are having a problem the latency on the first external hop is usally high. Disconnect/Reconect to get onto the good gateways ive listed above.
Mines okay pings are 17ms ish and speed is full using gateway ptn-ag2
Good luck Sad
ADSL speed test 58 kbs ....still trying to connect and disconnect ...
I have but ended up back on the dodgy one after using BT's speedtester...
Though the speed wasn't much better on the other gateways (actually I've used all 4 tonight - all pretty poor).
passer
I'm on thn-ag1
speeds normal for this time of the evening.
how many are there?
My speed is slow on AdslG but very fast on PN and it seems that the BT speedtester is down, won't load for me at all
http://217.35.209.142
PROBLEM SOLVED
Connected now to ptn-ag1 and life is good !
Thanks for the advise and help !!!!!!!!!!111
strathbungo: Did you change your router to login to the speedtest@speedtest_domain login (think those are right).
Yeah but even then FF was saying the connection was reset by the server, I tired one of the other ip addresses and it worked! Using a PN connection and the Speedtest login I got a result at line speed so I assume the ADSLGuide Tester was a bit slow
