Terrible Pings - What is happening
Fixes: 57
I haven't seen any comment from PlusNet as to what is happening to the pings tonight and last night.
These are typical results
Microsoft Windows XP [Version 5.1.2600]
(C) Copyright 1985-2001 Microsoft Corp.
C:\Documents and Settings\James>tracert www.bbc.co.uk
Tracing route to www.bbc.net.uk [212.58.224.89]
over a maximum of 30 hops:
1 <1 ms <1 ms <1 ms 192.168.0.1
2 148 ms 180 ms 167 ms lo0-plusnet.pte-ag1.plus.net [xxxx]
3 206 ms 164 ms 163 ms ge0-0-0-403.pte-gw2.plus.net [84.92.4.2]
4 151 ms 154 ms 156 ms ge0-0-0-22.ptn-gw1.plus.net [212.159.4.1]
5 150 ms 134 ms 128 ms gi1-1-22.ptn-gw5.plus.net [212.159.4.6]
6 138 ms 140 ms 145 ms rt0.thdo.bbc.co.uk [212.58.239.25]
7 154 ms 157 ms 164 ms 212.58.238.149
8 162 ms 160 ms 156 ms www52.thdo.bbc.co.uk [212.58.224.89]
Trace complete.
C:\Documents and Settings\James>tracert www.plus.net
Tracing route to portal.plus.net [212.159.8.137]
2 164 ms 163 ms 163 ms lo0-plusnet.pte-ag1.plus.net [xxxxxxx]
3 135 ms 136 ms 142 ms ge0-0-0-403.pte-gw2.plus.net [84.92.4.2]
4 160 ms 165 ms 160 ms ge0-0-0-22.pte-gw1.plus.net [212.159.4.9]
5 147 ms 149 ms 151 ms atm1-0.ptb-gw1.plus.net [212.159.1.89]
6 163 ms 159 ms 150 ms vlan18.pri.ptb-gw4.plus.net [195.166.129.130]
7 162 ms 151 ms 154 ms if2.ptb-al1.plus.net [195.166.129.39]
8 156 ms 164 ms 165 ms portal.plus.net [212.159.8.137]
Trace complete.
jepp
looks like SAME problems as last month - pings way up, d/load speeds way down...
PN speed checker showed WAY less than 1Mb on a 2Mb link, but BT speedtest shows near normal speeds of about 1600Kb....
traffic throttling anyoneHuh?
and with this months usage being 1.71Gb i don't expect to have such poor speeds
Evil
**Awaits this thread to be locked - then to be sent to another thread which fails to answer the issue**
A regular occurrence these days :roll:
paco2k5,
Not at all. If this thread is with regards to a new issue such as protocol or service then it would be unwise to lock the thread.
Some threads are locked due to them serving little or no purpose or for being a repeat of what is already being discussed on the boards.
Regards,
Just to anoy poeple
1 <1 ms <1 ms <1 ms 192.168.32.1
2 * * * Request timed out.
3 7 ms 6 ms 7 ms gr1-stbc-rtr1.homechoice.co.uk [81.1.112.62]
4 6 ms 6 ms 7 ms 81-1-67-48.homechoice.co.uk [81.1.67.48]
5 7 ms 7 ms 7 ms 81-1-67-16.homechoice.co.uk [81.1.67.16]
6 8 ms 6 ms 7 ms 195.50.116.197
7 8 ms 7 ms 8 ms bbc-gw1-linx.prt0.thdoe.bbc.co.uk [195.66.226.103]
8 8 ms 7 ms 7 ms 212.58.238.153
9 8 ms 8 ms 7 ms www26.thdo.bbc.co.uk [212.58.224.126]
Grimbo
Yea, I noticed horrific pings on Monday night...
Playing Call of Duty 2 and had pings of 100-150 (I normally get 50-60).
Don't know if it was a one-off as I haven't been back on yet.
jagger
paco2k5,
Regards,
What,like this one?
http://portal.plus.net/central/forums/viewtopic.php?t=39347
Neil_A
We published a service status earlier today relating to a config error on the network which caused issues for gaming. This should be resolved and current indications are that this is solved but if you see problems tonight please let us know.
terrible again tonight on BF2
Same Here :x
Yep, pings still high here too. Problem not solved.
Also Usenet playing up again...
Neil_A
Our engineers are looking at this now. Can you post problem traceroutes please
Fixes: 57
Still bad
Tracing route to bbc.co.uk [212.58.224.131]
2 115 ms 115 ms 114 ms lo0-plusnet.pte-ag1.plus.net [xxxxxxx]
3 110 ms 119 ms 119 ms ge0-0-0-403.pte-gw2.plus.net [84.92.4.2]
4 121 ms 119 ms 118 ms ge0-0-0-22.ptn-gw1.plus.net [212.159.4.1]
5 129 ms 125 ms 120 ms gi1-1-22.ptn-gw5.plus.net [212.159.4.6]
6 122 ms 123 ms 119 ms rt0.thdo.bbc.co.uk [212.58.239.25]
7 137 ms 137 ms 136 ms 212.58.238.133
8 134 ms 130 ms 131 ms rdirwww-vip.thdo.bbc.co.uk [212.58.224.131]
Trace complete.
I've been getting problems like this for this past week. The internet performs very well early in the day and afternoon, and then from between 4 and 5pm onwards, it is terrible.
I have problems opening webpages, and terrible pings to any online game.
When it comes round to midnight/ early morning, the problems that I experience in the evening are gone and all is well again.
From what I have read about the "peak-time usage management", it seems like it may have something to do with this, as the times fit perfectly within "peak time".
However I don't believe we are on any sort of management, and even if we were, this seems rather rediculously restrictive. It is almost impossible to use the internet during this period.
How much bandwidth must be used before any kind of restriction is put in place, as "my usage" shows we have used approximately 14 or 15 Gb this month so far.
Yesterday evening I was using both PlusNet's and ADSLguide's speed tests, and was consistenly getting very low speeds of between 200 and 400 kbps, although tonight is slightly better at between 1000 and 1100 kbps.
Seeing this thread, I thought I would try a Trace to plus.net to see what I would get, and I don't think this is normal:
1 * * * Request timed out.
3 * * * Request timed out.
4 * * * Request timed out.
5 * * * Request timed out.
6 * * * Request timed out.
7 * * * Request timed out.
8 60 ms 61 ms 62 ms portal.plus.net [212.159.8.137]
Trace complete.
Any help would be appreciated.
Thanks,
paco2k5,
Regards,
What,like this one?
Indeed. I have to admit they are one of the same. Lets see how things pan out.
