Sudden drop in speed
Anybody noticed a drop in speed, started about 4pm. BT Speed Test is fine.
BT Speedtest
1921 kilo bits per second (Kbps), your service bandwidth will have been quoted to you in kilo bits per second
ADSLGuide
Downstream 1010 Kbps (126.3 KB/sec) 1090 Kbps (inc. overheads)
Upstream 243 Kbps (30.4 KB/sec) 262 Kbps (inc. overheads)
Plusnet Speedtest
09-10-2005 16:36:12 1006.3
09-10-2005 16:32:25 1060.4
LiamM
Seems fine here...
Ditto Liam!
Strange, still running slow using PN but fast with BT tester. Hope this is only temporary after all the speed problems I've had in the past few months.
09-10-2005 17:13:25 1056.2
BT @ 17:15 1776kbps
Drop In Speed
I have noticed a drop in speed and I am on Home Surf 512K on Basingstoke exchange.
Regards
Ian
Re: Drop In Speed
How much of a drop in speed have you seen gardeni ?
Moderators note by John (johnessex) Unnecessary full quote of preceding post removed.
Back to normal now, wonder what caused the slowdown :?
BT 1925 kbps
PN 1944.1 kbps
AG 1906 kbps
LiamM
Could be a BT issue in your area that has now been resolved.
Yea possibly BT Evil , thanks for the replies btw Cheesy
Moderators note by John (johnessex) Full quote of preceding post removed.
Slowed to half speed again, BT test still showing no problems (1925kbps) :?
Gaming ping is usually about 20ms, currently at 130ms
Tracing route to portal.plus.net [212.159.8.137]
over a maximum of 30 hops:
Trace doesn't look too good.
1 5 ms <1 ms <1 ms 192.168.0.1
2 130 ms 127 ms 131 ms lo0-plusnet.ptn-ag1.plus.net [195.166.128.123]
3 125 ms 129 ms 131 ms ge0-0-0-103.ptn-gw1.plus.net [84.92.3.17]
4 127 ms 131 ms 131 ms gi4-0-23.pth-gw2.plus.net [212.159.4.21]
5 136 ms 135 ms 138 ms atm0-1-0.ptb-gw1.plus.net [195.166.129.246]
6 267 ms 141 ms 136 ms vlan18.pri.ptb-gw4.plus.net [195.166.129.130]
7 133 ms 142 ms 159 ms if2.ptb-al1.plus.net [195.166.129.39]
8 140 ms 210 ms 141 ms portal.plus.net [212.159.8.137]
Any CS like to comment ?
holdtight
Ive noticed it big time since about 4pm getting timeouts on some sites ebay especially also cant access the exchange checker and the forum is taking an age to load
Doing a traceroute to ebay the problem seems to be state side as it stops dead at sacramento but this doesnt account for the drop in speed and site access problems which has been a nightmare and is still going on now 11:20pm
1 1576 ms 1 ms 1 ms 192.168.1.1
2 1535 ms 18 ms 18 ms lo0-plusnet.ptn-ag1.plus.net [195.166.128.123]
3 18 ms 18 ms 20 ms ge0-0-0-103.ptn-gw1.plus.net [84.92.3.17]
4 52 ms 18 ms 18 ms gi4-0-23.pth-gw2.plus.net [212.159.4.21]
5 42 ms 24 ms 25 ms atm0-1-0.ptb-gw1.plus.net [195.166.129.246]
6 59 ms 25 ms 25 ms vl4.pri.ptb-gw3.plus.net [195.166.129.226]
7 60 ms 25 ms 25 ms if2.ptb-al1.plus.net [195.166.129.39]
8 60 ms 23 ms 25 ms portal.plus.net [212.159.8.137]
Hmm same time as when my connection slowed also. Its speeded up a little now. Hope this is just a temporary problem. What exchange are you on ?
Jus tried a trace to ebay.com and get the same as you, stops at sacramento.
