Sudden & Dramatic Drop In Speed
Fixes: 132
Suddenly my speeds have reached rock bottom which is unusual for my connection
I'm on Premiere 2 and used less than 13GB of allowance so have not hit any restrictions yet.
My Stable rate is: 7000
Namesco struggled to give the follwoing result:
DL: 79kbps UP: 75kbps
A BT test gave the following:
IP profile for your line is - 6500 kbps
DSL connection rate: 448 kbps(UP-STREAM) 7648 kbps(DOWN-STREAM)
Actual IP throughput achieved during the test was - 285 kbps
My Stats:
Local Line Atten: 2.0 dB
Remote Line Atten: 4.5 dB
Local SNR Margin: 14.0 dB
Remote SNR Margin: 26 dB
Couldn't find anything in PN's Service Status.
Any advice, please.
Cheers
Edit: I noticed my Sync speed has dropped from just of 7600 to 7008
Forum Moderator and Customer
Fixes: 132
My modem is now reporting the following:
Speed
UL: 0 kbps
DL: 262752 Kbps
:lol:
mrchalk
Been having speed problems lately myself, syncing at 4500 but speed is just poo & varies grately from 7-400kbps. Annoying.
mrchalk
Plusnet Staff
Plusnet Staff
Is that the sync speed the modem's reporting now? If so there's something seriously odd going on. What happens if you reboot the modem/router?
Fixes: 132
Yes, that was the sync speed reported by the modem. I had previously done a reboot.
A refresh of the modem brought back the previous display of 7008 DL & 448 UL.
Current speed test from Speedtest.net is showing:
Latency: 501 (has been as high as 1000 over the last three hours)
DL: 302 (has been as low as 25)
UP:349
Any idea why the sudden change? I have had reasonably good speeds on average (4500-5500) since being maxed last May.
Cheers
BTW email speeds appear to be fast. Don't know of any way to test their speed, though.
Julie
try testing your speed with this site http://www.speedtest.bbmax.co.uk/
Speedtest.net is not very reliable tonight
yeh that site is good, just make sure you choose the dussledorf server, for some reason its 3x faster than the london one Tongue
Fixes: 132
I use four different Speedtest sites, all gave similar results over the last thre hours.
Latest test results:
http://www.speedtest.net/ - 668 DL 373 UP
http://myspeed.visualware.com/ - 483 DL 273UL
http://www.speedtest.bbmax.co.uk/ - 1431 DL 362 UP
http://www.numion.com/ - 133 DL 385 UP
Cheers
Fixes: 132
yeh that site is good, just make sure you choose the dussledorf server...
Re-did test with Speedtest.net:
Dusseldorff: 2357 DL 378 UL
London: 1201 DL 363 UL
So, which reading is likely to be a true likeness to my speed? It definitely feels like London - even slower than that.
Cheers
how about here?
http://www.thinkbroadband.com/speedtest.html
i get
Date 23/01/07 00:04:28
Speed Down 4118.62 Kbps ( 4 Mbps )
Speed Up 369.41 Kbps ( 0.4 Mbps )
which is pretty accurate, considering my profile says 4500kbps
Fixes: 8
If you have synced at a low speed it probably means your BT IP Profile speed has been clobbered. Sad
What result do you get from http://speedtester.bt.com/ ?
If I'm right it's going to take about 3 days for your speeds to get back to normal.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Fixes: 132
I did a test as soon as the speed dropped so dramatically and the results were in my OP.
I have just done another test as follows:
IP profile for your line is - 6000 kbps
DSL connection rate: 448 kbps(UP-STREAM) 7008 kbps(DOWN-STREAM)
Actual IP throughput achieved during the test was - 5463 kbps
Why would my profile dropped by 500kbps whgen I have good line stats (see OP) and currently?:
Local Line ATten: 2 dB
Remote Line ATten: 4.5 dB
Local SNR Margin: 17 dB
I currently sync at 7008 kbps.
But at least the speed has returned Smiley
Cheers
James
As Jelv's suggested, your router may have had a random resync event, bringing down the IP Profile to match. If you maintain sync rates at the current level you're getting, it may improve slightly further.
I got the same problem as well!
speed test result is only 77Kbps!
I am in Manchester
