Strange Connectivity problem
Hi, I wonder if anyone can offer some advise on this problem.
I connect to the net using a direct connection to a Netgear DG834N. My general connection to the net is fine but periodically I can't get either Microsoft Messenger or Trillian to connect. They just report they cannot connect.
Some of the time if I reboot the router its fine but not always. However if I hook up my DG834G the problem seems to go away.
I can only assume the two units are handling certain ports differently but alas this is just a guess.
Can anyone tell me how get the “N” working as I cant keep the “G” permanently connected?
these last couple of days I've been having the same problem with MSN, and I'm using an 834g
Have you tried updating the router's firmware?
yup they are both up to date
