Staying in sync but LCP up and Down (Revisted)
Anyone else been getting LCP down disconnects again.
NOTE: this is not a SYNC failure.
Thu, 2005-11-24 06:16:00 - LCP down.
Thu, 2005-11-24 06:16:03 - Initialize LCP.
Thu, 2005-11-24 06:16:03 - LCP is allowed to come up.
Thu, 2005-11-24 06:17:04 - Initialize LCP.
Thu, 2005-11-24 06:17:04 - LCP is allowed to come up.
Thu, 2005-11-24 06:18:04 - Initialize LCP.
Thu, 2005-11-24 06:18:05 - LCP is allowed to come up.
Thu, 2005-11-24 06:19:05 - Initialize LCP.
Thu, 2005-11-24 06:19:05 - LCP is allowed to come up.
Thu, 2005-11-24 06:20:06 - Initialize LCP.
Thu, 2005-11-24 06:20:06 - LCP is allowed to come up.
Thu, 2005-11-24 06:20:57 - CHAP authentication success
Thu, 2005-11-24 06:21:07 - Initialize LCP.
Thu, 2005-11-24 06:21:07 - LCP is allowed to come up.
Thu, 2005-11-24 06:22:07 - Initialize LCP.
Thu, 2005-11-24 06:22:07 - LCP is allowed to come up.
Thu, 2005-11-24 06:22:16 - CHAP authentication success
Thu, 2005-11-24 06:32:27 - LCP down.
Thu, 2005-11-24 06:32:33 - Initialize LCP.
Thu, 2005-11-24 06:32:33 - LCP is allowed to come up.
Thu, 2005-11-24 06:32:36 - CHAP authentication success
Thu, 2005-12-01 00:46:46 - LCP down.
Thu, 2005-12-01 00:46:52 - Initialize LCP.
Thu, 2005-12-01 00:46:53 - LCP is allowed to come up.
Thu, 2005-12-01 00:47:53 - Initialize LCP.
Thu, 2005-12-01 00:47:53 - LCP is allowed to come up.
Thu, 2005-12-01 00:48:54 - Initialize LCP.
Thu, 2005-12-01 00:48:54 - LCP is allowed to come up.
Thu, 2005-12-01 00:49:55 - Initialize LCP.
Thu, 2005-12-01 00:49:55 - LCP is allowed to come up.
Thu, 2005-12-01 00:50:55 - Initialize LCP.
Thu, 2005-12-01 00:50:55 - LCP is allowed to come up.
Thu, 2005-12-01 00:51:56 - Initialize LCP.
Thu, 2005-12-01 00:51:56 - LCP is allowed to come up.
Thu, 2005-12-01 00:52:57 - Initialize LCP.
Thu, 2005-12-01 00:52:57 - LCP is allowed to come up.
Thu, 2005-12-01 00:53:57 - Initialize LCP.
Thu, 2005-12-01 00:53:57 - LCP is allowed to come up.
Thu, 2005-12-01 00:54:58 - Initialize LCP.
Thu, 2005-12-01 00:54:58 - LCP is allowed to come up.
Thu, 2005-12-01 00:55:59 - Initialize LCP.
Thu, 2005-12-01 00:55:59 - LCP is allowed to come up.
Thu, 2005-12-01 00:56:59 - Initialize LCP.
Thu, 2005-12-01 00:57:00 - LCP is allowed to come up.
Thu, 2005-12-01 00:58:00 - Initialize LCP.
Thu, 2005-12-01 00:58:00 - LCP is allowed to come up.
Thu, 2005-12-01 00:58:04 - CHAP authentication success
Was there 2 windows of maint during this time I wonder or are the ERX box's borking again the lcp echo replys ?
Plusnet Staff
Plusnet Staff
I've not seen any other reports but will keep a look out. With the times of day it's happening it could be BT Maintenance work, there's always rounds of maintenance work going on, almost always between midnight and 7am.
ceridwen
My log showed this, which is the first re-appearance of this fault since it was fixed:
Thu, 2005-12-01 03:57:41 - LCP down.
Thu, 2005-12-01 03:57:47 - Initialize LCP.
Thu, 2005-12-01 03:57:48 - LCP is allowed to come up.
Thu, 2005-12-01 03:57:51 - CHAP authentication success
Thu, 2005-12-01 11:09:22 - LCP down.
Thu, 2005-12-01 11:09:28 - Initialize LCP.
Thu, 2005-12-01 11:09:28 - LCP is allowed to come up.
Thu, 2005-12-01 11:10:29 - Initialize LCP.
Thu, 2005-12-01 11:10:30 - LCP is allowed to come up.
Thu, 2005-12-01 11:11:30 - Initialize LCP.
Thu, 2005-12-01 11:11:30 - LCP is allowed to come up.
Thu, 2005-12-01 11:11:35 - LCP down.
Thu, 2005-12-01 11:12:21 - Initialize LCP.
Thu, 2005-12-01 11:12:21 - LCP is allowed to come up.
Thu, 2005-12-01 11:12:34 - CHAP authentication success
The one at 3am I thought might have been related to the BTW maintenace, but I gather than was cancelled?
The 11am one, I can't explain.
Also (as I've mentioned before), for 4 days I had very poor internet access when the router would remain connected but after a few minutes not be able to send/receive data to the PN gateways. I was beginning to suspect hardware when this problem vanished. (see https://portal.plus.net/central/forums/viewtopic.php?t=36628 and http://portal.plus.net/central/forums/viewtopic.php?p=255054#255054). I don't know if these are both symptoms of the same problem?
Matthew
ceridwen
Just found this page over on Metronet (http://www.metronet.co.uk/adsl/exchangeChecker) from which I gather there was a problem at Reading which might have been responsible for the 11am blip this morning.
Matthew
Plusnet Staff
Plusnet Staff
Hi Matthew,
I can explain both of those, there was some maintenance this morning between 3am and 6am at your exchange and there was an MSO in Reading around 11am.
