Statit to Dynamic IP Address
How do i change my IP address from static to dynamic?
Try here;
https://portal.plus.net/my.html?action=control_your_broadband
What product are you on? That link may only work on BBYW.
Chilly
The_10th
Usually people want the other way around. Any reason for this?
p_w_d_stone
Some users worry that a static IP address means that you can be tracked on visits to websites, without the ability to do anything to change this, as you can with cookies.
Other users may find themselves being subject to DDOS attacks and have no choice but to change IP- this really should be done with collaboration with PlusNet though as this IP address will need to be removed from the available pool.
Or have been banned from somewhere Smiley
But seriously - I guess the another reason is some understandably don't like the RDNS of a static IP revealing their username. This can be turned off on request.
Not sure if this is the case with BBYW though.
lingbob
On BBYW, rDNS can be changed for a static IP but it can't actually be turned off. There's no automated process for this so a ticket has to be raised.
