Static IP address port number
Does anyone know what my static IP port number is or how to find out? I'm trying to access my router remotely which I've done on numerous occasions but its not working and I'm wondering if I'm doing something wrong. I have the static IP which is entered on the router but cant remember the port#.
Thx
Depends on the router which you forgot to mention.
Most use 80 (standard HTTP) or more commonly 8080
[append]
Sorry, did not notice your sig. DG834 uses 8080 unles you changed it yourself.
bingo 8080 it is and it is/was a Netgear DG834PN
Thx now connected and have managed to reboot router that had lost its connection
