Static IP address and DNS name
bartstope
hi there,
i'm on the broadband premier product and by default have a static ip address.
i've noticed that site counters and other logs record that username.plus.net has visited the website, which i have to say i find a little unnerving. is there a way this can be removed so it's just an ip address and not a dns name?
i'd like to keep my static ip address if possible, it's just that the dns name is my username, and since changing your username is impossible, i just wonder if removing the dns element is possible, if you get my meaning?
You can change your reverse DNS (rDNS) to an ip address via the contact us ticket system.
- Tech Support
- Static IPs, IP block requests & Reverse DNS Setup
- Change my Reverse DNS (PTR) configuration
