Starting to freak out really bad...
Ok...ive made 2 topics but this one is different, so, as before i am getting slower download speeds on my main pc than on the older pc which is connected to this one to use the internet, what reaaaly threw me was when i was downloading software for the old pc it was downloading at 233kbps, i was like 'omg!!...' anyway... i am still getting about 1/4 of my adverage download speed on 1 pc, also when you upgrade to 2meg is it instant caus this morning i had 512 but when i checked like an hour ago its on 2.2meg
You get 2mb total not 2mb per PC!
If you have one PC maxing out at 220kb/s then there's nothing left for the other one.
nonono, i did 1 download on my main pc which is connected directly to modem and the speed was really slow likw 50 kbps compared to the other one which i did afterwards which was 220 kbps, i dont see why there should be any change in speeds, any idea?
P.S oh yea games work fine aswell, no lag whatsoever
How are you connecting them, via a router? Which kind? or is it Wireless, if so what standard are you using?
ok, my main pc is connected directly via usb to the modem, my other pc is connected to this one by a normal 10 meg network cable(would use fire wire but dont have the right cable for it) would there be something wrong with my internet settings thats screwing it up?
