Started dropping out again
Got a netgear router on 2mb connection for 21.99.. only drops out on weekdays..
cant check snr with netgear does that crappy modem supplied by plusnet give them details??
also im not fillin a ticket till im 100% sure its not my equipement.. as i pay 21.99 and i expect 2mb for that price so..
ports on my exchange are amber will this cause the problem?? shudnt do.. but could it?Huh
Which modem have you got?
hi there,
have you looked at this http://portal.plus.net/central/forums/viewtopic.php?t=30717 ??
John give some good info there and maybe that could help you ?
hi, thanks for your reply.. lookin at that there is a section there about connection dropping when idle.. yes my connection drops when idle.. i have looked in my router and 0 is selected.. so that shudnt disconect??
found my line stats
System Up Time 07:15:50
Port Status TxPkts RxPkts Collisions Tx B/s Rx B/s Up Time
WAN PPPoA 12 11 0 21 44 00:01:04
LAN 100M/Full 13716 0 0 38 0 07:15:48
WLAN 11M/54M 35486 20153 0 815 154 07:15:40
ADSL Link Downstream Upstream
Connection Speed 2272 kbps 288 kbps
Line Attenuation 39 db 23 db
Noise Margin 16 db 24 db
i have looked in my router and 0 is selected.. so that shudnt disconect?Huh
Not sure, but in my router I have option to tick a box "Allways on" next to "idle timeout" When this is ticked the default number of 300 for "idle timeout" changes to "-1" So perhaps you could try setting yours to "-1"! Wink
Have you read this Netgear thread:
http://portal.plus.net/central/forums/viewtopic.php?t=30516
Simon
