Stable rate
Stable rate
It is still at 3000kbps and my router is reporting from 4000 to 4900kbps. Reset the magic button.. please? Wink
(Random topic.. it's sunday!)
Plusnet Staff
Plusnet Staff
Stable rate
How long has it been sync'd at 4000kbps or higher? In order to increase the throughput to 3500 you need to be sync'd at 4000kbps or more for at least 3 days, if it drops below 4000kbps at any point then that 3 day clock will reset.
Stable rate
Dave,
I was changed to Max three weeks ago, the lowest my sync has been is 4800kbps its usually over 5000kbps.
My stable rate has never changed from 2000kbps since the day I was maxed, I have tried disconnecting, leaving the router on for over three days etc, (TBH it is never normally switched off).
So something ain't working somewhere. :roll:
Stable rate
I see.. As far as I have checked the router. I did disconnect on and off for 3 days which the sync rate seen from 3776kbps to 4776kbp (esitmated guess!). At the moment, it is syncing at 4000kbps since Thursday I think.. Thanks for the information though!
Re: Stable rate
There's a magic button?
Modem been at 8128/448 for 1 month, and stable rate shows 2000Kbps - link to thread
