Stable rate 2mb been connecting at over 7 for over 2 weeks !
petsyb
Hi
https://portal.plus.net/my.html?action=stable_rate still says I'm connected at 2mb even though my modem connection for the last 15 days has never dropped below 7mb and was today connecting at 8mb
i have had nothing but slow speed since getting put on max Cry
will someone at plusnet please set my stable rate to what it should be
Petsyb.
BT report – still slow and well below 400kbps for 8 MB
http://portal.plus.net/central/forums/viewtopic.php?t=43779
How long till stable rate set on MaxDsl (so slow) ?
http://portal.plus.net/central/forums/viewtopic.php?t=43759
Why Oh Why Oh Why ! 7.3mb but actually 500k
http://portal.plus.net/central/forums/viewtopic.php?t=43592
Plus net stable rate set way to low - please reset !
http://portal.plus.net/central/forums/viewtopic.php?t=43417
8mb upgrade slower than my old 2 mb !
http://portal.plus.net/central/forums/viewtopic.php?t=43175
MAXDSL - Constant Disconnections
http://portal.plus.net/central/forums/viewtopic.php?t=43334
MAXDSL Modem trained 7424kbps actual 318kbps WHY ? ? ?
http://portal.plus.net/central/forums/viewtopic.php?t=43291
Plusnet Staff
Plusnet Staff
This is a known issue which BT are currently working on and part of the reason they closed the bulk regrade tool 2 weeks ago.
We are hopeful that this problem will be fixed shortly and those customers affected by this will see the BT BRAS profile (which the stable_rate figure represents) corrected.
The bulk regrade tool is due to re-open later this week and we should know more then about the fix for this particular problem.
Ive had problems to recently https://portal.plus.net/my.html?action=stable_rate keeps on telling me
"Your current broadband speed is 500 Kbps"
Why is it so slow!!!Huh it should be at least 1mb
Plusnet Staff
Plusnet Staff
What speed does your modem/router say you are sync'd at? In order for the BRAS profile (and thus the stable_rate figure on the portal) to change to 1Mbps you need to be sync'd at 1152kbps or higher. If it drops below that then the throughput will decrease as well and will only go back up after at least 3 days sync'd at 1152kbps or higher.
Might be worth taking a look through
http://usertools.plus.net/tutorials/id/10
and
http://usertools.plus.net/tutorials/id/13
to see if anything there helps to increase the sync rate.
My ADS Max connection speed is also now set at 500kbps.
After trying to get through on the standard support number yesterday and being advised there was a 40 minute wait, I called the premium rate rip-off line and got through immediately.
I was told to run the 3 standard BT speedtests and open a call. But what's the point of going through this process if the stable rate has been set at 500kbps by BT? Surely all the speedtests will do is confirm the obvious - i.e. the speed has been set ridiculously low.
My router has consistently synch'd at around 3770 Kbps and soon after the service was enabled my connection speed was around 3 Meg and pretty stable.
If you try to open a call through the Plusnet support portal you have to go through a tortuous sequence of questions and then if you can't give the correct answers the calls self-close. Adding a comment to try to explain the situation in the hope that a human might interpret it correctly is equally useless.
Suggestions such as run a virus check seem pretty pathetic when the stable rate has already been set at 500kbps - or am I missing something?
My modem has been synching at 8128/448 for 1 month now, and my stable rate is still 2000Kbps - link to thread
Well after checking my SNR and attenuation figures I can see why the speed is now so poor. Downstream noise margin is showing as just 6 dB and attenuation is 47 dB. There has been a physical fault on the line for the past few weeks which was supposedly fixed yesterday but it seems that the loss on the line is the issue and that's why the 500kbps has been set.
Now I need to find out how to get the line fixed properly by BT. I previously had a 1Mb service in the house next door to this one and had no problems. I am plugged into the the master phone socket here and the internal wiring is all brand new.
Noise margin not SNR
Actually, having read more, it seems that the 6 Db noise margin is OK. I was thinking it was 6 dB SNR. In which case, I'm still not certain how I can go about trying to get the 500 kbps limit increased.
Our companys BT ccounts manager says they have no peroblem with regrading and it is sour grapes from people as there are no sync issues.
I asked him, "Have you read the news on the net and in the press?"
He said, he does not know what I am talking about!!!
To be fair to plus-net - this is WHOLLY a BT issue and nothing else!
At least be thankful that soon you will ahve a proper maxdsl connection!
I will NO DOUBT get mine in September, but I might move on by then as I like watching premiership footy and it is not possible with plusnet as they cripple it!
