Stable Rate
Bizlat
Stable Rate
Test1 comprises of Best Effort Test: -provides background information.
IP profile for your line is - 1000 kbps
DSL connection rate: 448 kbps(UP-STREAM) 1376 kbps(DOWN-STREAM)
Actual IP throughput achieved during the test was - 478 kbps
Can u move ip throughput up please, Thanks. Sad
Plusnet Leader
Plusnet Leader
Stable Rate
The IP throughput will be determined by your sync speed and BT line profile. This is something that automatically adjusts given the condition of your line.
I would advise plugging the router into the BT master socket without any extension cables and ensuring you have microfilters on all active phone sockets in your premises.
If you sync at a higher rate with the exchange for 72 hours then the profile will automatically increase as will the throughput.
Plusnet Leader
Plusnet Leader
Stable Rate
I've made some changes to your account which should increase the speed for you.
Reboot your router and you should see a faster throughput speed Cheesy
