Stable Rate Tool Garbage ??
aetos
Is the Stable rate tool Garbage
Your High-speed Broadband Service
Your current broadband speed is 8000 Kbps
What does this speed mean?
This is the speed that the network supplier is telling us you should expect on your line. If your hardware is reporting higher speeds, you can try and automatically update this speed by disconnecting and reconnecting once a day for 3 days.
I am still showing as
Date Speed Achieved (kbps)
26-05-2006 13:53:30 1899.7
25-05-2006 17:30:38 1905.8
24-05-2006 21:12:12 1906
23-05-2006 20:51:54 1859.1
23-05-2006 20:51:35 1281.6
23-05-2006 20:51:17 1497.9
22-05-2006 18:37:30 1908.4
22-05-2006 18:04:21 1896.1
22-05-2006 17:09:34 1909.2
21-05-2006 22:47:33 1923.7
21-05-2006 20:44:00 1911.3
18-05-2006 17:04:23 1896.7
18-05-2006 17:04:05 1608.8
18-05-2006 17:03:44 1896.6
18-05-2006 15:18:35 1918.6
18-05-2006 15:18:01 1908.2
18-05-2006 15:16:27 1922
18-05-2006 15:16:03 1912.3
18-05-2006 15:15:43 1696.4
18-05-2006 14:06:38 1901.3
IS this a dream or imagination
MArk
Fixes: 57
But have you been changed over to Max - what is the synch rate your router is reporting.
The reason for asking is that if you aren't on Max then the PlusNet report does say 8Mb as it is the default value when no information has been provided by BT
aetos
Still waiting for MAX, bone of contention
Fixes: 8
The answer to your original question is NO. It only applies to users who have been upgraded - until then it shows you the "up to" speed for your account type.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
