Stable Rate Stuck. PlusNet Please nudge it
pacem
My Stable rate is stuck at 1000kbs. Syncing at 1824kbs and have been for 9 days ( http://ccgi.pacem.plus.com/router.php?days=7&day=4&month=3 )
There doesn't seem to be an easy way to raise this regularly occuring problem in the ticketing system.
...so if anyone knows an easy way of raising a ticket or someone in the comms team happens to be reading. I'd be very grateful.
Paul.<><
Plusnet Staff
Plusnet Staff
What does the BT Speedtest say?
http://www.plus.net/support/broadband/troubleshooting/bt_speed_tester.shtml
In particular you're looking for the IP profile.
Bizlat
Test1 comprises of Best Effort Test: -provides background information.
IP profile for your line is - 1000 kbps
DSL connection rate: 448 kbps(UP-STREAM) 1600 kbps(DOWN-STREAM)
Actual IP throughput achieved during the test was - 428 kbps
Can +net put mine back up to a 1000 currently set at 500kbps Cry
Mand
Hiya,
Now changed back to reflect the BT data. A quick reboot should sort it out for you. Smiley
Bizlat
Thanks Wink
pacem
Just my luck:
Test Error
The system is currently busy. Please try again shortly, however if this problem persists, raise the issue with your service provider.
Paul.<><
Plusnet Staff
Plusnet Staff
Fixes: 159
Unfortunately this does happen with the BT tester, perseverance is needed to get results sometimes.
 Chris Parr
 Plusnet Staff
dont want to hijack this thread but can i have my stable rate bumped up please ..... did ask in another thread but no reply ..... it was on 1500 then dropped to 1000 when rebooting all the time for a better gateway when we were all having speed probs ....
speedtest results :-
IP profile for your line is - 1500 kbps
DSL connection rate: 448 kbps(UP-STREAM) 1728 kbps(DOWN-STREAM)
Actual IP throughput achieved during the test was - 872 kbps
Plusnet Staff
Plusnet Staff
Fixes: 159
@snipperuk
This updated about 15 minutes ago for you to 1500, you should be back to the speeds you were seeing before.
 Chris Parr
 Plusnet Staff
thankyou chris Smiley
sorted
lank111
how's it going pacem? any better?
Also, what program/script do you use to get your stats online!
pacem
Well after a couple of router reboots etc, I go to do the speed test tonight only to find my stable rate has automagically increased to 1500, so I don't need to do the speed test (Yay!)
As for the software. It's a simple crontab bash script that I wrote to collect the data every minute, and once hourly upload it to the cgi space:
#!/bin/bash
SNRFILE=adsl_advance.html?ImPorts.a1
SPEEDFILE=adsl.html?ImPorts.a1
OUTPUT=output-`date +%j`
THISDIR=/home/paul/router
cd $THISDIR
test -e pause && exit 0
test -f $SNRFILE && rm $SNRFILE
test -f $SPEEDFILE && rm $SPEEDFILE
wget -q http://admin:password@router/configuration/$SNRFILE
wget -q http://admin:password@router/configuration/$SPEEDFILE
test -f $SNRFILE || exit;
test -f $SPEEDFILE || exit;
## grep ">0 day 0 hr 0 min" $SPEEDFILE > /dev/null && echo 0, 0, 0, 0, `grep '0</td' $SPEEDFILE | sed -r s/\<.?td\>//g | sed -r s/0$/0,/g` `date +%T` >> $OUTPUT
echo `grep dB $SNRFILE | sed -r s/\<.?td\>//g | sed -r s/\ dB\ */,/g` `grep '0</td' $SPEEDFILE | sed -r s/\<.?td\>//g | sed -r s/0$/0,/g` `date +%T` >> $OUTPUT
date | grep ":59:" && scp -C $OUTPUT pacem@ccgi.plus.net:
exit 0
For the scp to work you need to have configured your public private key.
This will only work for my Billion 7400 router at the moment but I'm sure tweeking the greps and the URL of wget would allow it to work with most routers.
It's output is just a simple list e.g http://ccgi.pacem.plus.com/output-023
The php side on the cgi server then plots the graphs as required. I'm not a php programmer and it's pretty ugly code but it does the job; each image is less than 8KB. It was also my first go at doing SVG.
I may have another go at showing the php code but exporting it to phps doesn't seem to render without extra headers so I'll need to tamper with things to make it readable. It's too big to paste here. (Post if you're interested least I forget.)
EDIT:
The main control page code can be found here: http://ccgi.pacem.plus.com/router.html
and the code to draw the graphs is: http://ccgi.pacem.plus.com/svg2.html
(Not that this was strictly asked for, but we're all entitled to a little vanity...)
Paul.<><
mcgoo
could someone nudge this for me.I am getting 1.4mb.
DSL connection rate: 448 kbps(UP-STREAM) 6976 kbps(DOWN-STREAM)
Actual IP throughput achieved during the test was - 1373 kbps
If you wish to discuss these results please contact your ISP.
If you are experiencing problems with specific applications, servers or websites please contact your ISP for assistance.
Your test has completed please close this window to exit the performance tester.
lank111
Very cleva! i need a simple network traffic grapher, anyone has any ideas?
i have a D-link wireless router with SMNP,
looking at the MRTG package? anyone used it before
