Speeds yet again
Eebuygum
Speeds yet again
Download speeds absolutely dire this afternoon, BT Speedtest reporting 230KBps, other speedtesters saying much the same.
Whats going on ?
fakesnake
Speeds yet again
hi. same thing here, gone from 6500 to 250KBps.
bobbygeorge
Speeds yet again
same here !!
quite disgraceful ..
wonder if it's anything to do with 'ptn-ag2'
for some reason I just simply cannot get off it despite constant reconnects.
anyone elso on this gateway with probs ..
Snarf
Speeds yet again
Same here, after only having just got my connection up to 2500kbps, speedtests are now indicating ~400kbps. I'm on BB Premier 1, anyone else on this package being affected?
Any PN guys around to say whether contention has come into it, or is there another fault somewhere?
Speeds yet again
I'm also on BB Premier 1.
Until recently I was gettting speed test in the 4000 to 6000 region - even at peak time.
Now:
Come on plusnet - what are we paying for on Premier? I won't let this go for very long without jumping ship.
EDIT - I seem to have been getting these speeds at peak time since the new capacity, and changes to improve bb+ have been implemented.
EDIT AGAIN:
BT Speedtest result:
Test1 comprises of Best Effort Test: -provides background information.
IP profile for your line is - 7150 kbps
DSL connection rate: 448 kbps(UP-STREAM) 8128 kbps(DOWN-STREAM)
Actual IP throughput achieved during the test was - 1292 kbps
Snarf
Speeds yet again
Hmm for me it would seem it was a problem/contention with one of PN's servers. Just disconnected and reconnected and speeds are back up to normal.
Speeds yet again
Well that's interesting.
Just tried the same thing (switch router off/on):
And back to normal.
fakesnake
Speeds yet again
just rebooted my router
not really any better.
jerryw
Speeds yet again
Same here, back in June when we got MAXed the speeds averaged
1500kbps, lately it's a third of that and today just 200kbps !
There was a suggestion on Usenet that PlusNet will give discount(s) for poor performance.
Anyone knows the full SP on that ?
Regards,
Martin
Snarf
Speeds yet again
Check what gateway you're connected to here.
I'm currently on ptn-ag1. Make sure you're reconnecting to a different gateway as it may be a problem on a certain one. Usually disconnection for a few seconds jumps it onto a new gateway.
Speeds yet again
Ouch the same here;
I am just going to try some gateway hoping, see if I can improve things.
Chilly
Speeds yet again
Hopped to pte-ag2 and now getting 2M. Cheesy
Chilly
Speeds yet again
I have also had problems with the internet today. This morning I was unable to use the internet because of the large no. of errors showing. Rebooting reduced these but at one stage, I was unable to bring up internet sites. Rebooting to "bt_test@startup_domain" worked fine and the digital demo site loaded instantly. My normal connection didn't connect to the internet despite the stats now being reasonable. I left it for a couple of hours and came back to try pings and tracert and everything worked fine.
I rebooted a number of times and initial sync speed was 5000+ which is unusual for me. I have to bring this down by configuring the snr because I know it will not cope with peak hours.
I am waiting for a visit from BT so there's nothing I can do at the moment but today the signs were that PN must have had some problems.
fred
fakesnake
Speeds yet again
hi, just done a reboot and
still on'ptn-ag2'
Speeds yet again
OK Plusnet
Any suggestion as to why we now need to re-boot to get sensible speeds?
