Speeds fine for UK sites
My speeds are great for UK sites, but as soon as I try to access a site outside the UK it dies.
RE: Speeds fine for UK sites
what do you get here
http://wiggum.monitor.plus.net.uk/
I get a glorious 489.40kbps
And at ADSL guide I get
Downstream 467 Kbps (58.4 KB/sec) 537 Kbps (inc. overheads)
Upstream 243 Kbps (30.4 KB/sec) 279 Kbps (inc. overheads)
PlusNET Technologies Bandwidth Meter
Your current bandwidth reading is:
97.00kbps
which means you can download at 12.13 KB/sec. from our servers.
i get this at the moment
And at dslreports I get a terrible
Your download speed : 102711 bps, or 102 kbps.
A 12.5 KB/sec transfer rate.
Your upload speed : 79051 bps, or 79 kbps.
530.30kbps
which means you can download at 66.29 KB/sec. from our servers.
Shame that downloading or uploading to any other site other than plusnet's means it goes 2kb/sec or slower Sad
My prob is that im a new customer and am not certain what i should get but i get really poor speeds from this site http://wiggum.monitor.plus.net.uk/
77.40kbps
which means you can download at 9.68 KB/sec. from our servers.
but only in the evenings. I was thinking it was because of these other probs plusnet are having. BUT you guys get good speed here so im wondering now if i have other issues that i will need to sort out as i believe that there is no problem on the asdl network, or have i got this wrong.
I can't even connect to it!
tssk
Mine is a 56k dialup connection from
Batemoor, Sheffield
I have to say tho, I can't say as I have seen any problems with my connection of late... I must be one of the lucky one's.
39.20kbps
which means you can download at 4.9 KB/sec. from our servers.
"If you can't be a good example, then you'll just have to be a horrible warning..." Catherine Aird
this is what i get :
480.90kbps
which means you can download at 60.11 KB/sec. from our servers.
