Speed upgrade
Speed upgrade
Im currently on option 1 premier which max speed is 8mb
If i upgrade today to the option 3 package upto 24mb...would that mean i would be upgraded to the 24mb or is that 24mb for future when it comes out?
csogilvie
Speed upgrade
When it comes out, which may depend on whether you are on a Tiscali LLU line or a BT Whoelsale one, too.
Speed upgrade
As Colin says, the greater than 8Mbps products do not currently exist and we don't know when they will. You may also need new hardware to support the faster connections (which are ADSL2+). All accounts are (slowly) being upgraded to 8Mbps so the only current differentiating factor between the Premier products are the usage limits.
