Speed test
Speed test
Hi guys&girls&other Cheesy
Been having a few probs with speed going up and down, one min its all go go go, then its all slow slow slow ,
I have the 2 meg prem account, but as you see from my speed test it seems to be a lil bit over that at times, then its all stop.
I used the speed test and used the best config from a site called errrr, (lost the link Shockedops: ) it did improve the speed a lot, but whats with the test saying the speed I get is 52400.9 kbps for my 2 meg account and yet, on the chart it should be normaly ADSL 2000 1840 kbps for a 2 meg account
Its not a complaint as such,just a question from a num skull Smiley
PlusNet Speed Test
Your current speed is:
51.17 Mbps
Which means you can download at 6.4 MB/sec. from our servers.
53.3 kbps 56k Dial Up
64 kbps ISDN 1 Channel
128 kbps ISDN Dual Channel
460 kbps ADSL 500
920 kbps ADSL 1000
1840 kbps ADSL 2000
52400.9 kbps YOU
The following table shows the speeds you achieved from previous runs of the speed tester:
Date Speed Achieved (kbps)
26-06-2005 10:00:05 60532
26-06-2005 09:59:34 0
26-06-2005 09:58:23 56238
Same here!
I have the half meg line and have been running speed tests since I got the email that my account will be upgraded before the 29th of June Smiley
Heres what the plusnet speed test says:
PlusNet Speed Test
8.78 Mbps
Which means you can download at 1.1 MB/sec. from our servers.
460 kbps ADSL 500
920 kbps ADSL 1000
1840 kbps ADSL 2000
8989 kbps YOU
26-06-2005 10:58:55 11521.8
26-06-2005 10:57:31 5747.4
26-06-2005 10:53:23 4879.1
None too shabby methinks, right?
_____________________________________________
Well, no! Heres what http://www.adslguide.org.uk says my connection is:
Broadband Speed Test Results
Results from broadband speed test recorded on Sunday, 26 June 2005, 11:03.
Your Connection
Direction
Actual Speed
True Speed (estimated)
Downstream 435 Kbps (54.4 KB/sec) 469 Kbps (inc. overheads)
Upstream 247 Kbps (30.9 KB/sec) 266 Kbps (inc. overheads)
Whats going on here like?
Speed test
I asked a similar question earlier as per below...
Having recently been informed of speed up grade I decided to check my speed. I've just checked 4 times each alternatively on Plusnet and ADS Guide speed testers.
Plusnet averages around 960Kbps; ADSL Guide averages around 1870Kbps
Who do I believe?
I was advised to try the BT speed test. I have done and find that averages around 1600Kbps. (incidently BT suggest that anything between 400 and 2000 as acceptable!)
I think you just take your pick :?
Speed test
The speed test has completed on test server speedtester1.nat.bt.com for user *********** and you have downloaded a 1.7Mb file at a speed of
1877 kilo bits per second (Kbps), your service bandwidth will have been quoted to you in kilo bits per second.
Your IP address is **********, your browser is reported as being Mozilla 5.0 and is running on Windows XP.
BT would regard the speed ranges shown below as normal service:
For 250kbps End Users speeds between 50 - 250kbps.
For 500kbps End Users speeds between 100 - 500kbps.
For 1000kbps End Users speeds between 200 - 1000kbps.
For 2000kbps End Users speeds between 400 - 2000kbps.
Well looks like I can use my smug grin :lol:
As is stated, you take your pick, depends on if your an optimist or pesimist I would think Smiley
There again it may have to do with how much valium you take :lol:
BT speed test?
Where is the BT speed test?
Julie
Speed test
