Speed problem
snapper_mart
Speed problem
My connection speed has sudddenly dropped to around 200-300 kbps on a 2MB premier account. I've done all the checks, but the problem is still there on both my main PC and two laptops bt speed test says 1800kbps. Any ideas?
M
Speed problem
Have the 200-300kbps speeds been reported by the Plus Net speed test or what are you using to measure this?
Have you tried an ADSL Guide speed test?
Speed problem
Also, if you are prepared to say, how much have you downloaded so far this month (or billing period)? I'm really interested if you have downloaded a lot during the peak hours (more than 20GB) and (although not shown on VMBU) what you think you have downloaded between 8am and midnight. in he past month.
snapper_mart
re speed problem
Hi Peter,
I've downloaded 1.78GB so far...I'm not a heavy peer to peer user...in fact I seldom download large files, I've only ever downloaded more than 20gb in a month once or twice. The speed test results have come from Plus net's speed tester and ADSL Guides tester, I have raised the issue with support.
Speed problem
I just tested mine almost 300kb/s
