Speed issues
Speed issues
I've been monitoring this for two weeks now with speeds between 440k and 4000k with the average at 1.7k for an 8k service.
Just used the BT speedtest where I see the following
IP profile for your line is - 5000 kbps
DSL connection rate: 448 kbps(UP-STREAM) 5792 kbps(DOWN-STREAM)
Actual IP throughput achieved during the test was - 3778 kbps
Using the PN speedtest I get 850k?
Plesae can you look at this for me.
Thanx
Speed issues
alankay
Speed issues
Using the PlusNet speed test over the last few weeks has provided me with some interesting results to say the least!
Today was no exception......I have been maxed this week but the figures lower down seem rather excessive :shock:
Speed Achieved (kbps)
22-11-2006 19:13:04 1678.7
22-11-2006 17:46:03 4394.1
22-11-2006 17:45:42 0
22-11-2006 15:17:44 0
22-11-2006 15:17:29 175543
22-11-2006 15:17:04 189046
22-11-2006 13:23:27 204800
22-11-2006 13:23:00 223418
22-11-2006 13:22:41 0
Fortunately tests on other sites prove more reliable
Speed issues and test reults
The results I get from the tests are
adslguide - 4328 down and 370 upload
speedtest.net - 1468 down and 379 upload
speedtest.bbmax - 4556 down and 369 upload
Any help?
I realise that there are bandwidth probs earlier but will try these again at 8pm tomorrow to see if there is any difference.
Thanx
Fixes: 8
Speed issues
What does https://portal.plus.net/my.html?action=stable_rate say?
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Speed issues
What does https://portal.plus.net/my.html?action=stable_rate say? This gives 5500kbs.
Thanx
James
Speed issues
Given the speed results that you are getting on the other speedtesting sites (speedtest.net is a little unreliable), I'd say that your profile and general speed seems to be about right.
OK, many thanks for your help. I will keep an eye on things for a short while. Looks as if I will have to live with it for now.
Once again thanks
