Speed issues - floods?
Hi folks
I am experiencing a dramatic drop in my speeds, is this caused by the floods or something else?
Here's some stats
Router: BT Voyager 2100
Line Rate
Downstream = 4608 Kbps
Upstream = 448 Kbps
Noise Margin
downstream = 14.5db
upstream = 21.0db
Line Attenuation
downstream = 29.0db
upstream = 20.0db
BT Speed Test Results
IP profile = 4000Kbps
throughput = 216 at worst 72 Kbps
ThinkBroadband
dowstream = 219.88
upstream = 96.15
+Net @ 22:41
261Kbps
Any thoughts??
Regards
Simon
p_w_d_stone
Doesn't look like this is related to weather or flooding as your sync rate is fine.
Therefore, please can you complete a BT Speedtest (see help here) to check your IP profile.
As it's towards the end of the month can you also check if you've exceeded your usage allowance.
Already done that, result is in my post
Done that too, nothing untoward there
Sim
p_w_d_stone
Sorry, I missed that as I was busy with other threads.
As throughput is low on the BT Speedtester, it doesn't sound like an RWIN or MTU issue. The puzzle is that your sync rate is so high compared to the throughput, the difference is too large to be explained away by exchange contention.
I take it you were the only user using the connection at the time and that no P2P apps were running? What spec computer did you use for the speedtests and how is it connected?
All tests done from this PC, other PC are not switched on, which is connected by ethernet cable to router. Router is A1 secure, no one is taking a free ride on my BB connection. Wink
No p2p, ftp, or streaming apps running, just plain ol'browsing
Sim
Hi again,
Speeds have gone back up
Im happy again now.
Sim
Plusnet Staff
Plusnet Staff
You might want to take a look at this:
http://www.plus.net/support/broadband/products/archive/bb_plus.shtml
You can check your current usage under View My Usage under Connection Settings on the left.
I have a similar issue. As of yesterday morning I am experiencing speeds of 0kb/s down on P2P applications (regardless of the time), however uploading is working just fine. I have no idea what's causing this and I haven't used much of my monthly allowance.
Can a member of staff please check this?
Thanks!
Mand
Is it only P2P that's affected? I've had a look at your account and can't see anything untoward.
If you could raise a ticket with as much information as possible I'll get one of the networks guys to investigate this for you in more detail.
