Speed at off peak...
Test1 comprises of Best Effort Test: -provides background information.
IP profile for your line is - 7150 kbps
DSL connection rate: 448 kbps(UP-STREAM) 8128 kbps(DOWN-STREAM)
Actual IP throughput achieved during the test was - 3561 kbps
Hi, surely it should be higher, and why has my profile at 7150, I'm only 600 metres from the exchange...
ChrisC
Zathras
Whats wrong with 3561 kbps?
Yep - well you can't be on BB+ then with that speed Smiley
Zathras
And unless youre on payg you cant use it for anything Cheesy
Hi, what's wrong? Well I used to get up to 6600 kbps that's why.
Anyway, just had a e-mail from +net explaining that there are broadband performance issues. That might explain it...
ChrisC
That's an understatement. My link has dropped from 7Mb to 500K this afternoon.
I wish I got 500k, its more like 50 k here
Hi, edit my reply, meant 6600k's of course, duhhh
ChrisC
And to show what it is capable of at peak times:
Last Result:
Download Speed: 6475 kbps (809.4 KB/sec transfer rate)
Upload Speed: 299 kbps (37.4 KB/sec transfer rate)
Actual IP throughput achieved during the test was - 5398 kbps
ChrisC
