Speed Testers
ColinG
Speed Testers
Should I see a significant difference between the PlusNet and BT speed testers?
Running tests on both speed testers over the last few days, at various times, gives these results:
PN: 13-11-2006 10:06:46 2210.9
BT: 13/11/2006 10:06 4661
PN: 13-11-2006 09:58:50 1695.4
PN: 13-11-2006 09:58:28 2363.3
BT: 13/11/2006 09:57 4793
PN: 13-11-2006 09:57:40 1738.8
BT: 13/11/2006 02:52 5147
PN: 13-11-2006 02:47:31 2311.1
PN: 12-11-2006 23:41:20 2199.2
BT: 12/11/2006 23:32 4814
PN: 12-11-2006 23:25:30 2155.7
BT: 12/11/2006 11:18 5285
PN: 12-11-2006 10:55:41 2017.1
I went on MaxDSL about a month ago and the router always syncs at 8128000.
AT first my exchange was red so the bad results where expected however last week the exchange went green and although the BT speed tester results have improved PlusNet's have not.
Any ideas?
Speed Testers
looks like you just need to request to have your IP profile reset Cheesy
James
Speed Testers
Yes, it does sound like the ip profile at our end does need changing, probably owing to a lost delta report. From Monday, we should be able to do this manually, but unfortunately it is not currently possible.
ColinG
Speed Testers
Thanks, WIll raise a ticket.
